Question about ViewSonic VX912 19" LCD Monitor
Veiwsonic vx912 - ficking on/ off every few seconds
HI - Have a time served Veiwsonic VX912 (which I love).  Recently started flicking off every few seconds making it unusable - think it resets - the image returns as normal (but only for a few seconds).  The power light also goes off and then comes back but not exactly at the same time.  May have access to another Power unit and spares for same model.
Any tips or ideas .... (and how does the back cover detach safely (4 corner screws removed - but still doesn't seem clear at the top).
Thanks in antidipation of your replies
G
    New Friend:
Try different video cable or check it, if not power supply.
Posted on May 09, 2017
2 Suggested Answers
  • 224 Answers
SOURCE: vx912 case removal
Please Note: all the LCD monitors are power packed with air pressing, you will need to pull the frame from front to remove the case, it is very simple and easy, just pull it softly with equal pressure on the corner.
Posted on Sep 30, 2009
Remote makes tv start to operate then flicks of to standby immediately
Hi Barrym,
You have not mentioned anything about the make and model of your TV. If you do so, it will help us to suggest you the solution. Your TV is going in the protection mode as soon as you switch it on. There can be several things responsible for this. A proper check can decide the actual cause. Please consult some local TV tech.
May 31, 2015 | Televison & Video
My 19 inch ViewSonic monitor shows red /voilet
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Apr 25, 2010 | ViewSonic VX912 19" LCD Monitor
Power button flashes but screen is blank except for very brief flashes of desktop image
hi, probably the transistors on the main power board. if these go bad, the capacitors should be replaced as well. repair shops charge 40-70 dollar to repair. i have repaired in past and they last maybe 2 more years after. may want to get another monitor and throw your up for sale broken on ebay.
Mar 10, 2010 | ViewSonic VX912 19" LCD Monitor
Vx912 case removal I've taken off 4 mounting screws & 4 others in corners. Case still fixed firm. Don't want to break clips - where do I apply force please?
Sep 30, 2009 | ViewSonic VX910 19" LCD Monitor
Headlights flick on and off
Check your relay but most of the time it's your light switch that has gone bad. The swithch heat's up after a while and then that when the flickering happens if not stop working. Good luck and hope this helps
Apr 08, 2009 | 1989 Ford Mustang
Screen not working
check if the source is correct, VGA / DVI.
also make sure your resolution set on the computer is not higher or mhz is correct.
Mar 21, 2009 | ViewSonic VX912 19" LCD Monitor
Hi there, my viewsonic monitor VX912 is not getting a signal from my computer. I first checked to see if the connections were good. No joy ther! so I then tried to see if the cable was faulty(my monitor...
Is your tv HD, it may have worked on the digital signal, but perhaps it switched to a HD program, and it doesnot support that HD signal, If not it may be a switching problem
Dec 16, 2008 | Evesham Computers & Internet
Viewsonic VX912 Distorted screen
for meantime use the previous monitor suitable to your pc then download the files you need enabling the new monitor to work.
Oct 15, 2008 | ViewSonic VX910 19" LCD Monitor
Where?
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
BER-2 Number: D9 SCRAP NOT AUTHORIZED
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Apr 08, 2008 | ViewSonic VX910 19" LCD Monitor
The problems is my monitor (VeiwSonic VX910) is blinking evey few seconds from destktop screen to black screen. help!!!
PSU- Board, Rev.C
Jan 08, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX912 19" LCD Monitor Logo
267 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
