Question about Fisher and Paykel GWL11 Top Load Washer
Won't Power On
I lucked out today (or so I thought) and found a brand new Fisher & Paykel GWL11 on clearance today at Lowe's.  Usually $599, it had been marked down to $125 because it had been repaired.  (I've gotten these type of repaired-new appliances before there and have never had any trouble.)
The ticket noted that the washer had been delivered to a customer and would not power on.  As a result, is was returned to the store and the repairman changed out the control board (420094USP) and touch control board (421098P).  The store said the problem had been fixed.
As luck would have it, the delivery men delivered and installed it today at my house, and together we discovered it still doesn't power on.  I'm trying to get the situation resolved with Lowe's and the repair company, but things are moving slow.  Any ideas?
  • LaundryMom Oct 24, 2007
    Thanks, but I've tried that several times.  I was finally able to reach the repair service that worked on it at Lowe's.  Not much help, though.  They got the repair man on the other line who said it worked fine after he fixed it (yeah, right) and all I had to do was program the control panel.  I've reviewed the manual, called F&P, and searched the web, but can't find anything on programming the control panel.  I'm thinking that's not the answer.
Water sometimes leaks in the pump motor and shorts out the control board. Lean it back against the wall an see if the pump shows signs of leakage. If he replaced the control with out the pump it could to took out the control again.
Posted on Apr 23, 2009
Unplug it for 30 seconds then plug it back in - that seems to work
Posted on Oct 24, 2007
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel GWL11 will not power on (yes the circuit is on)
Check the water pump under the machine. These pumps fail, but are easy to replace. Ours was short circuited and actually sparked when the power button was pushed. Same no lights, no power. We had a GWL10 model, but I'm sure the GWL11 is similar.
Aug 13, 2014 | Fisher and Paykel GWL11 Top Load Washer
How do I repair Fault Code #40 on Fisher & Paykel washer GWL11?
I googled it and found this:
http://www.genuineapplianceparts.net/techsheets/gwl11techsheet.pdf
Jul 20, 2014 | Fisher and Paykel GWL11 Top Load Washer
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
No power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
The drain/circulation pump quit on my fisher paykel gwl11
Checked the control board for a fuse.  Found two fuses on the printed circut board.  Checked both for continuity, one had none a 6.3 amp fuse sodered into the board.  went to a local electronics store and purchased a similar and replaced fuse.  Everything works fine now.
Jan 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Wasehr won't power up
brand new???? call an authorized servicer. as long as your electric is good .all you can do
Jan 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
386 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
