Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Problem with motor; need to open the motor compartment
I have an old kenmore bagged canister vacuum but I think it's similar to the above model.  How can I open the motor compartment in the canister so I could work on the motor.  I don't see any screws and it's difficult to pry the canister apart.  Thanks.
  • 2 more comments
  • amandabarton Nov 21, 2007
    I have the same problem. The motor is running really loud and I can't get the thing apart to look at it.
  • Anonymous Dec 19, 2007
    i have a kenmore similar to the picture above. I can't get the cover off the motor. I found two screws but the other two must be under the on/off switch. Is there a trick?
  • johndhawley Feb 20, 2008
    I need to access the motor compartment on my Kenmore Powermate Canister Vacuum. I do not see any screws or tabs.
    Please notify when a solution is found (I need to replace the electric cord retractor and vheck the motor brushes).
    John
  • Anonymous Feb 11, 2009
    I have a whispertone canister vacuum model 8540 and I can't pry the cord return pad up to get it off I have tried everything and it won't come off??
This may help. My Kenmore is ten years old. I found two screws under the hinges of the cover to the tool accessory compartment. Remove cover screws are in the corners. The other two I found are under the cord return foot pad. Pad pops off by prying up. I hope I explained it so you will beable to understand..
Posted on Dec 07, 2008
    President:
  • 1,673 Answers
The top piece near the back comes off, use a screw driver to pry the corners out then it will come off. Then you can get to the 2 screws holding the motor housing off. When you put it back on, it just snaps in place.
Posted on Jan 10, 2008
If your're trying to take the cover just squeeze the sides on topwhere
the lights are and it will come off. then there are two screws to
remove and the bottom will come of providing you use a
screwdriver where shown
Posted on Mar 06, 2009
My 30 year old canister vac has had both the filter and bag changed, but everytime I turn it off the bag compartment opens and ejects the bag.
I think its time for a new vacuum cleaner.....sounds like the circuitry is malfunctioning or you have an airflow problem that is tricking the vacuum into thinking the bags full. check all hoses and airways for blockage
Nov 14, 2010 | Electrolux Guardian Bagged Canister Vacuum
Where are screws located that access main motor compartment in panasonic canister MC-V9647? Something is rattling inside and smells hot. Belt or motor?
If the model is the same as pictured, the screws should be visible.
If the model is older like I think it is, the screws are going to be a tad tough to get to, but not impossible.
First you will need to take the bag door off. Open it like you would to change the bag and then push the bag door back farther so that the hinges "pop" out. Generally how i do it is put it on the counter, with the bag facing you, open as far as you can, grab the top portion of the bag door and push it back quickly.
Now, when the bag door is off, with a flat screw driver, the colored housing above the gray bumper will come off. insert the flat screwdriver in there and pry it open a touch. do that to the other side as well. Once both sides are open, you want to slide the screwdriver towards the back of the unit and gently pry the back off.
under there you will find 2 screws (if you need to go that far at this point) and you can remove the back of the unit easily.
Good luck,
Mark
Nov 08, 2010 | Panasonic Kenmore Canister Vacuum Vacuum
How do you change the bag in a kenmore progressive true hepa canister vacuum?
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Power cord caught in rewinder, Sears bagged canister. 10 yrs old
Hi There,
I'm sorry, I didn't get your comment on your previous repair. In order to get the cord reel out of the canister, here's what you'll need to do:
I have uploaded2_bing.gif a parts diagram of your model below so that you can follow along:
Step 1. Open up the tool lid as if you were going to remove the dusting brush or crevice tool from the top of the vacuum2_bing.gif. Once the lid for the tools is open, simply grab the two arms at the base of the lid, and pull forward towards the front of the vacuum where the bag connects. You'll need to remove the tool lid completely from the rest of the vacuum. You may have to lift slightly upwards while pulling forwards to remove the lid.
Step 2. After you've removed the tool lid, now open up the lower part of the tool lid that covers the vacuum bag (Part 29 in diagram above). While this cover is open all the way, grab the two arms on this part as well, and pull towards the front of the vacuum where the bag connects, and slightly upwards, just as you did to remove the tool lid. Remove the vacuum bag lid completely from the vacuum cleaner2_bing.gif as well.
Step 3. There are two visible screws that are now visible (The screw listed as number 16 that's directly underneath of the number 36) on the front corners of the motor housing. Remove both of these screws that are in the front corners of the motor housing.
Step 4. There are actually two more screws that are hidden on this model, that are located underneath of the foot pedal that retracts the cord reel. You'll need to now remove the foot pedal from the vacuum cleaner (part 36 on the diagram). In order to do this, use a flat head screw driver to pry off the foot pedal. Insert the flat head screw driver in the front of the pedal where the pedal meets the motor housing. There are 4 tabs that hold this pedal in place. Usually if you put your flat head screw driver in the middle of the pedal where two of these tabs are right next to each other, the pedal will come off right away. Insert your flat head screw driver where I have circled red, these are the two tabs that you want to pry off. Simply push towards the rear of the vacuum while the flat head screwdriver is inserted in between the foot pedal and the motor housing:
Step 4. Now that you have the foot pedal off of the canister, simply remove the two now exposed hidden screws (oh yea watch out for that spring that's underneath of the pedal! remember to put this back when putting the pedal back), and lift straight up on the motor housing. You'll now have full access to the cord reel so that you may push the cord back through the hole in the rear of the vacuum cleaner.
Please feel free to use the Clarification Request form here on the repair page if you have any questions, or need some further help in accessing the cord reel. If your cord reel has gone bad, we do carry all the parts for your vacuum, and we'd be more then happy to provide any part that you may need. Here's a link to the bags for your vacuum on our site, just in case you need to purchase some:
Kenmore 5055 Canister Vacuum Cleaner Bags, 9 Pack.
I really hope that this helped you. If you have any further questions, I look forward to hearing from you. If this was helpful to you, please be so kind and return the favor by rating my repair solution helpful. You may do this by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is really what keeps repair professionals like myself continue providing free repair services, and it's greatly appreciated.
Thanks again,
Chris Jones
GoVacuum.com
Apr 11, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Feb 16, 2009 | Kenmore Vacuums
Kenmore Vacuum model #116.25813508
In yours there is a pcb asm, #KC86WBZRZ000 , you probably need to replace it.
Sep 01, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
219 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
