Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Motorola k1 cannot format unformatted memory card
My motorola k1 dispalys unformatted memory card. but when i choose to format the memory card, it displays " format failed"
    New Friend:
  • 14 Answers
Sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Posted on Feb 27, 2013
    President:
  • 782 Answers
Try first in pc. Use FAT or FAT16 fprmat - NO NTFS. Then insert in to phone and format again .
Posted on Jun 04, 2009
My motorola w490's problem is it cannot read my memory card,it always says that (inserted memory card:unformatted)
The problem is that your card is not formatted well..Try to format it by connecting to a computer either by phone or by card reader..
now right click the memory card drive and select the format option on the tab.
after the completion of format remove it form computer and insert it on your mobile..
now it will detect your memory card..
i request you to kindly rate me on fixya if i am helpful..
Dec 18, 2010 | Motorola Mobility W490 Cellular Phone
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
Memory card will not format
No. The maximum size of memory card supported by this model is 1GB microSD type only. So it wont recognize your 2 GB memory card.
Aug 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola k1 not formatting memory card
hi,
This may be because your phone does not support that ype of memory card. get another one and see if it
May 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
which hand set ur using? and try 2 empty few space so that it should run in ur hand set
Motorola k1 is nt reading memory card
try 2 format in some other motorola set and then put it in ur handset. its ur hardware problem that says remove card when u close ur cover try take it out ur memory card and then u watch it says same?
May 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 not reading memory card
have both phones upgraded on the firmware or have them reflash
May 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola phones often require memory cards to be formatted in order to be used. Go into your Setting and Tools menu. From there it depends on which carrier you have and which version of their software, but you're looking for an option for Memory or Storage Devices. It may be under Device Info, Phone Info, or another similar header. Again, the exact menus will vary between carriers and software versions.
Once you locate the menu for Memory/Storage Devices you should see an option for the Memory card. Select it, then choose Options (right soft key) and you'll see the Format option.
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
442 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
