Question about X2 1.9GHz AMD Turion 64 Mobile TL-58 35W 2x512KB TMDTL58 PC Notebook
Shows low speed in speed test
Having AMD turion 64X2 mobile tech TL58 1.9GHz processor. In speed test shows only 800MHz speed. why?
  • 74 Answers
Hi
Send me more details about your motherboard & Operating System
Harry
Posted on Aug 08, 2009
Hello, I would like to overclock my AMD mt30 CPU 1600Mhz25wattTDP 64clockspeed/power ratio to that of a SempronML37 2000Mhz35WattTDP and 57.1 clock speed/power ratio? Do I just change the voltages in...
Due to the way you stated the above John, you seem like a guy that will understand the following;
Yeah know funny thing about overclocking;
1) You may have a good Processor that came off the assembly line that day, or it may be one that just squeezed past Quality Control. Push it too much, and it will fry. Trying to make it hit 2.0GHz all day long, every day, may just push it over the limit. Sure you may have read about, or even heard of someone who did it. How long? How long did the processor last at this overclocked rate?
2) AMD's run H-O-T. Not a good idea to push a Processor with overclocking (Which makes it run MUCH hotter) in a cramped laptop environment, with a low cooling capacity anyway.
3) Ram Memory typically operates at half of the FSB Frequency Rate ('Speed'), that the Processor does. (Front Side Bus)
To overclock you can;
A) Change the Voltage
B) Change the FSB frequency rate ('speed')
C) Change the Multiplier
If you change the Front Side Bus frequency rate too far, the ram memory will not work anymore.
Won't match.
AMD Turion 64 MT-30,
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Lancaster.22_.2890_nm.29
The Sempron you name is a Turion also.
Turion ML-37,
4) You have to have a BIOS Setup Utility that will allow you to change CPU parameters.
See this article?
http://www.ehow.com/how_7335931_overclock-turion-64-compaq-nx6125.html
No mention that overclocking a Processor shortens it's 'Life Span'
No mention that if overclocked too far the Ram Memory may not work.
No mention that an AMD processor runs HOT, and if you overclock you'd better have a lot more than the factory cooling. Plus not a good thing for a laptop anyway because of a laptop's poor cooling design. (Cramped small space, small fan, inadequate cooling thermal module)
No mention that the BIOS Setup Utility in your laptop may not have a CPU Soft option, or options inside that allow you to change the Processor's parameters.
No mention that you should go slow. Change parameters in one SMALL increment, wait 24 hours, and check the system. Looks okay? Change parameters another small increment. Check during a 24 hour period. Keep going until the computer starts messing up, then go BACK to the last parameter that checked out okay
Have I dissuaded you yet?
No?
Just don't want to see someone fry their Processor, or computer.
Okay.
The Turion MT-30 has a clock multiplier of 8 times. (8x)
The Turion ML-37 has a clock multiplier of 10x.
The Turion MT-30 uses 1.35 Volts (DC)
The Turion ML-37 uses 1.35 Volts (DC)
The Turion MT-30's Front Side Bus frequency rate is 800MegaHertz
The Turion ML-37's FSB 'speed' is 800MHz.
What options in your BIOS Setup do you have for changing CPU (Processor) parameters?
State back in a Comment. (Believe top right of your page)
No options?
Then try CrystalCPUID, or ClockGen,
1) http://crystalmark.info/software/CrystalCPUID/index-e.html
2) http://files.extremeoverclocking.com/file.php?f=189
3) http://www.cpuid.com/
Regards,
joecoolvette
Sep 18, 2011 | AMD Turion 64 Mobile MT-30 1.6GHz 25W 1MB...
Will a turion 64x2 processor from a av7170 interchange with a sempron processor in a 7115-eh1?
Processor Type 754-pin (uPGA); 638-pin (uPGA)*
Support Processor
AMD Turion64 X2 Dual Core
Processor,
AMD Turion64 Processor
(25/35W series),
Mobile AMD
Sempron™ (25W series)
Those are the ones that your laptop supports
Dec 17, 2010 | Averatec AV7170-EC1 Notebook
AMD Turion 64x2 Blows very hot air
try cleaning the CPU of dust with a fine air blower using an air compressor making sure there is no moisture in the air line
good luck with this
Sep 02, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Which is better processor between amd athelon ,sempron, turion 64
Hello rakeshmedita,
The Turion is more of a mobile processor meant for laptops since it uses less power while the athlon is for desktops and uses a bit more power. The Turion might edge out the Athlon on performance but will beat the pants off it in power consumption. The sempron is a low-cost processor meant for entry level desktops. So, to answer your question it goes Turion, Athlon, Sempron.
Hope this helps, if so please leave some positive feedback. Thanks.
Feb 16, 2010 | Dell Laptop InspironTM 1501 PC Notebook
My AMD Turion processor powered laptop runs slow intermittently
good day i also use a compaq laptop and i think you laptop is very fine just be frank you have so mch game in your laptop and am sure thats it.want does game increase your ram to maybe 4gb.
thanks.
Jul 05, 2009 | Computers & Internet
Can i upgrade the processor for my acer aspire 4520-5141?
Hi there
The computer can only support max 2.3 GHz x2 Turion CPU.
Thanks for using Fixya!!
Feb 12, 2009 | Acer Aspire 4520-5141 Notebook
Pci driver installation problem
AMD Turion 64X2 Mobile TL-52
Code name:Taylor
Instructions: MMX(+), 3DNow! (+), SSE, SSE2, SSE3, X86-64
Jan 11, 2009 | Acer Extensa Laptop
System specifications
Here's the HP Support link for your laptop.
Apr 23, 2008 | Computers & Internet
X2 1.9GHz AMD Turion 64  Mobile TL-58 35W 2x512KB TMDTL58  PC Notebook Logo
185 people viewed this question
Top X2 Computers & Internet Experts
David Payne
David Payne
Are you a X2 Computer and Internet Expert? Answer questions, earn points and help others
