Ensoniq MR-76 stops and starts on its own
I have a Ensoniq MR-76 keyboard that will start and stop playing tracks assigned to the drum machine any time it wants. In no certain pattern, just sparatically, and then sometimes it can sit in silence for a half an hour and not trigger itself at all.(so that any technician i take it to looks at me like im crazy) Then other times it will ''stop start, stop start stop start start, stop start start'' to the point you cant even lay down a track at all. If any one knows how to fix this problem PLEASE let me know how. Thank you.
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
I recorded drums to the internal click track/metronome and drums are in time with metronome when i play it back with the click from the start of the song. BUT, if i stop in the middle of the song and...
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
Jul 01, 2011 | Tascam 2488mkii 24 Track Recording...
Does anyone have a link to a user manuel for an Ensoniq MR-76 keyboard?
Take a look here: http://www.emu.com/support/welcome.asp?rd=download
Feb 27, 2011 | Computers & Internet
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 | Music
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Drums for MIDI track to not work
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
Jan 18, 2009 | Sony Acid Music Studio 7 Full Version for...
Don't know how to actually record
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
On the ZR-76 keyboard, no output on main or aux output jacks ok on headphone
Ensoniq zr-76 no output signal on the main and aux, but i have output on headphone jack?
Oct 15, 2008 | Music
Ensoniq MR-61 keyboard
reset that piano by giving it 20 min with power!!
plz aret this post
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
