Question about RCA Universal Remote 3 Device Remote Control
Unable to install my RCA Universal Remote Control
CAN NOT USE THE THE DIRECT CODE ENTRY METHOD.  ALSO HAVE TRIED THE MANUAL CODE SEARCH WITH NO SUCESS.
  • 1 more comment
  • billlybob Mar 09, 2008
    same
  • Spikecut Mar 23, 2008
    I Can Not get My RCA Remote Control Programmed To My VCR And DVD Please Help
  • phowell777 Aug 25, 2008
    I cannot get rca system link 3 to work with an admiral tv/vcr combo????
How do you install it to work in my tv i lost the instructions!!!!!!!!!!!!!!!!
Posted on Jun 19, 2008
  • kelispark Jan 26, 2012
    Me Yooo ;(
Step by step
What steps are you looking for? Also what is the problem? Also this may solve your issue
Copied from: voxrightnow
Programming the Remote:
Your universal remote can operate a variety of brands of components. In order for your universal remote to control your components, you need to program the remote with the codes that match the components (See Code List below). These codes enable the remote to communicate with your components. Each brand and each component has its own "language," and, by programming the correct codes into your remote, you tell the remote to "speak the same language" as your components.
There are two methods you can use to program your remote control to operate your components: Direct Code Entry and Manual Code Search and Entry. Most components can be programmed in one of these ways. Try them in the order listed.
In order to control combo TV/VCR or TV/DVD units, you must program both the TV key and the VCR•DVD key. Once programmed successfully, the TV key controls the TV functions on your unit, and the VCR•DVD key controls the VCR or DVD functions. There is a specific section in the Code List for combo units. The codes in this section should be tried first, using Direct Code Entry on the TV and VCR•DVD keys. If this is unsuccessful, follow the normal programming methods for both the TV and the VCR•DVD keys
Direct Code Entry:
To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2. Find the Code List below. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use the Manual Code Search method to program the remote control. (Refer to page 5 in the User Manual for Manual Code Search method, or scroll down in this Answer to the next section.)
3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry procedure, the LED indicator light blinks four times, and the process is exited.
4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key. If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure
for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3 and try the next code listed. The last programmed code under that component key is retained. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Manual Code Search and Entry:
If your component's brand isn't listed in the Code Lists, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Manual Code Search. This Code Search method cycles through all of the codes in the Code Lists in the event that your component's code is listed under another brand. The Manual Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand is listed in the Code Lists, first try the Direct Code Entry method described on page 4 in the User's Manual also described above.
NOTE: To exit without saving any point in the Manual Code Search, press and release the GO BACK key.
Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained.
2. If you are programming the remote to control your TV or satellite receiver, go directly to step 3. To program the remote to control a VCR or DVD follow the preprogramming method listed below.
Preprogramming the VCR/DVD Key
The VCR•DVD key can control only one component, either your VCR or your DVD. To program your remote to control either your DVD or your VCR, you must first put the remote in the proper programming mode. Follow these directions before proceeding to step 3.
a. Press and hold the VCR•DVD key. The LED indicator light turns on.
b. While holding down the VCR•DVD key, press and release the number 2 key on the keypad to control a VCR or the number 3 key to control a DVD. The LED indicator light turns off.
c. Release the VCR•DVD key. The LED indicator light blinks four times and then turns off. Your remote is now either in VCR or DVD Programming Mode, depending on which you chose. Proceed to step 3.
4. While holding the component key down, press and hold the ON•OFF key. The LED indicator light turns off.
5. After holding down both keys for three seconds, the LED indicator light turns back on.
6. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the
7. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component
turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
8. Once you have found the correct code, you must save the new
code by pressing and releasing the STOP key. The LED indicator
light turns off. You must press the STOP key to save the code or the correct code will not be stored!
9. Once you press the STOP key, the code is stored.
Testing the Code for Maximum Functionality:
1. Once the code has been stored (see Manual Code Search and Entry Method above), use the remote to attempt to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the
code stored does not give maximum functionality, you will want to try another code.
2. In that case, repeat the Manual Code Search and Entry Method from step 1. When the component turns off for the first time, do not press the STOP key, which would store the code. Instead, with the unit now off, continue to press the ON•OFF key repeatedly until the unit turns back on. Once the unit turns back on, you have found another code that operates the component. Press the STOP key.
3. Test the functionality again by attempting to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the code stored does not give maximum functionality, you will want to try another code.
4. Repeat the Manual Code Search and Entry Method from step 1. Each time a code turns the component on or off, you have found a code that operates the remote and needs to be tested for maximum functionality. Continue through the code lists, cycling through the codes you have already tried, until you find one that offers maximum functionality.
Nov 10, 2012 | RCA RCR350 Remote Control
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Can't program my rca rcr311w remote to my sanyo tv .
Hello
Setup codes to check with Sanyo TV with RCA RCR311W remote control are:
1047, 1078, 1080, 1121, 1129, 1163
you want the remote to control.
2. Locate the enclosed Code Lists.
to pages 7 and 9 for Manual and
Auto Code Search methods.)
wishto program. The illuminated
ON•OFF key turns on and
component key at any time
procedure, the illuminated
ON•OFF key blinks four times,
numbers, the illuminated
ON•OFF key turns off.
entered, the illuminated ON•OFF
key turns on. At this time, release
illuminated ON•OFF key turns
procedure for Direct Code Entry.
the illuminated ON•OFF key blinks
Entry process from step 3.
TIP
OK
Sep 14, 2011 | RCA Televison & Video
I cant program my rca remote on the tv
Hello
Setup codes for Toshiba TV with RCA RCR 311B remote control are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
Most RCA universal remote will have this code for Toshiba TV.
Programming method:
1* Manually turn on the component
2* Locate the enclosed Code Lists.
3* Press and hold the component key
4* While holding down the
5* After the fourth number is
OK.
Jul 14, 2011 | Toshiba 27A45 27" TV
How to program a rca rcr451 remote
or cable box).
component’s brand. You will see a
brand. If your brand isn’t listed,
control. (Refer to page 6 for
Manual Code Search method.)
(TV, VCR, DVD, SAT·CBL) you
your component’s brand and use the
light turns off.
component’s functions with the
your component’s functions.
DOWNLOAD the full manual with codes for free at: http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR450C-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | RCA Universal Remote Control
RCA RCR412b remote
Direct Code Entry
2. Locate the enclosed Code Lists. Find the
program. Find your component’s brand.
for each brand. If your brand isn’t listed,
pages 7-8 for Manual and Auto Code
Search methods.)
DVD, VCR·AUX, SAT·CBL) you wish to
program. (To program the VCR·AUX key
to control a component other than a VCR,
see page 7.) The illuminated ON·OFF key
illuminated ON·OFF key blinks four
times, and the process is exited. The last
programmed code under the component
key is retained. Toshiba codes:2011, 2029, 2030, 2033, 2093, 2107, 2110, 2111, 2112
Sep 13, 2009 | Televison & Video
Magnavox #27MS343S TV and the RCA Universal cannot find Code
Hello.
Try these codes for Magnavox..
002, 009, 109, 118, 309, 402, 408, 502, 508, 510, 807, 917
Hope this will help you.
Regards...
Tech5508/Goran
Feb 16, 2009 | RCA RCR311B Remote Control
Listed code for my Memorex DVD/VCR not working
I HAVE RCA RCA312W TV AND I NEDD THA CODE TO PROGRAN A SONYO TV
Jan 16, 2009 | RCA Universal Remote Control
RCA Universal Remote RCR4258
ive got the same problem.
Did you ever solve it
Sep 04, 2008 | RCA Universal Remote Control
I have a GE universal remote and want ot program it to work a Zenith VCR
You need the instruction manual that came w/ your universal remote control.Follow all installation instruction carefully.First use the Direct Code Entry.If any of the 4 Digit code from your Zenith vcr doesn't work,use the code search method instead.Be patient because RCA requires you to press the channel up button up to 300 times.Good luck.4TUNE
Jan 21, 2008 | Televison & Video
Televison & Video Logo
720 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
