Question about Motorola Mobility RAZR V3i Cellular Phone
Battery Problem My V3i battery goes off easily like about just two hours or so especially when using the camera, music, etc..
  • 105 Answers
Plz u change your set and use only nokia set
Posted on Jun 04, 2009
Camera wont charge. green light comes on for a second then a red light flashes and then goes out
This normally indicates a battery problem. Remove the battery and wipe the contacts (battery and camera) firmly with a dry cloth to remove any corrosion that may have built up on them. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning, remove any debris that may have fallen into the battery compartment, then insert the battery and connect the camera to the charger. If the green light stays on, the problem is gone and you can charge the battery for several hours and then use the camera. If the red light comes on, it's likely time to replace the battery - especially if it's more than a year old.
HINT: Always remove the battery if you don't plan to use the camera for a week or more. This will prevent corrosion buildup and extend both battery life and camera life.
Bill B
Apr 25, 2010 | Kodak Easyshare M753 Digital Camera
Sony Ericsson K770i does not hold charge :(
Replace the battery, but I am assuming you mean 10% per hour with normal use. If you are on the 3G, playing music, making calls, thats all you're probably going to get. Thats 10 hours, if you use it often I wouldn't expect any more. I charge my new Blackberry every night, and I have to.
If not, then definitely a new battery, because 10% per hour without data or music and usage, it must be the battery, probably replace the charger too if you want to be really really certain.
Jan 27, 2010 | Sony Ericsson K770i Purple 3G Camera...
Nokia n95 battery goes fast ... what should i do?
Dear, just do the following precautions to get your phone more long run along with entertainment.
  1. Set your phone display brightness to minimum
  2. Switch off Wlan and Bluetooth when not use.
  3. Listen music in handsfree instead of speakers.
Dec 18, 2009 | Nokia N95 Cellular Phone
Problem in music uploading for motorola v3i
sir install motorolla pc suit in your pc and connect via usb cable
Sep 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My new ipod 8gb has a really short life
If you put your iPod as "shuffle" mode, then it will use up more battery since the unit has to access the hard drive more than usual.
if you put in in "repeat" it will also use more than usual battery.
So, try to put your iPod right down, but your stereo up. Also, types of music files (wmp, mp3, mp4, wav, etc) affect your battery life as well. the higher the bitrates = more battery usage.
Also, try to keep using the iPod until it goes down to absolute 0% and turns itself off. Usually, the red part will last around 8 hours in most cases.
Hope this helped! ^_^ Have a great day~
Jun 26, 2009 | Apple iPod nano
My Motorola V3i keeps turning off by itself especially on calls.
well unfortunatly its def a battery problem.ul hav to get it replaced..u cud check it out with another battery borrowed frm a friend who has the same mobile
Thanks for using Fixya
Apr 28, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3i mobile phone fault.
have u tried removing the batteries and placing them back aft 10 to 15 mins....eitherwise i recommend u take it to ur service centre
Thanks for using Fixya!
tc
Sep 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
V3i
hi..ur motorola v3i is defaulted with 7 to 10 hrs of battery life only...o save more power...
  • Keep the brightness on the screen to a minimum. You can also adjust how long the backlight stays on without input from the user.
  • Turn off the Bluetooth when not in use. Bluetooth is a big battery draw.
  • Disable incoming beams so that the phone isn't constantly "searching" for infrared partners.
  • Completely close non-essential programs. When you run an application, it does not shut down completely when you "close" it. It is simply minimized. Go into the Settings to completely shut down any programs you are no longer using
  • also u cud get a car charger so that u cud be sure not to run out of juice..
    Aug 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola v3i
    most lifetime of motorola batteries
    Aug 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola Mobility RAZR V3i Cellular Phone Logo
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
