Will the Foxconn n15235 work with ym Quad core cpu, Q8200 mother board PT8907MB-2.0-8ERS2H
SOURCE: drivers placa base Foxconn N15235
Drivers placa base Foxconn N15235
Posted on Sep 23, 2008
Nic61
  • 1073 Answers
SOURCE: audio drivers are gone
After some searching for that MoBO i found out that the name of your MoBo is P4M800P7MB-RS2H
And here is all avaliblr drivers for it
http://www.foxconnchannel.com/support/downloads.aspx?product_type=Motherboard&product_series=Socket+775&product_model=P4M800P7MB-RS2H&product_id=en-us0000191
It the window "Search by download Type" you print P4M800P7MB-RS2H, in the window bwlow you select >DRIVERS, then you will see all drivers there is for that MoBO, select them you want and download them
Good luck to you
If you find my answer helpfull, plz dont forget to vote!
Posted on Dec 26, 2008
bob_computer
  • 3153 Answers
SOURCE: download network drivers for foxconn n15235
The FOXCONN website is you best place to start.
We dont send t email addresses I am afraid.
Sorry
Posted on Nov 27, 2009
mbase213
  • 728 Answers
SOURCE: foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Mark
Posted on Apr 24, 2010
map9966
  • 2351 Answers
SOURCE: Need specs for the N15235 motherboard.\r\nIt has a
The link provided by Foxconn shows all supported CPUs that will work on the Foxconn 6627MA-RS2H MB; http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&model=6627MA-RS2H&cputype=
Cheers'
Mike
Posted on Jun 06, 2010
Testimonial: "Except for not being able to use the link because you did not allow enough characters to be used for that line. It was helpful."
How Is a Q6600 core 2 quad cpu compatible with a foxconn g41 mxe-v motherboard?
Yes it's compatible. The type of motherboard can be any board that uses "Socket 775".
Aug 07, 2014 | Intel Computers & Internet
Foxconn n15235
Windows does that in Device Manager, it isn't the motherboard. If you have a Dual-core CPU, they'll show up as two CPUs, Quad-core as four CPUs, etc.
Dec 10, 2013 | Intel Computers & Internet
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
Does dual core processor support Foxconn P9657AA-8EKRS2H mother board
The Foxconn P9657AA-8EKRS2H motherboard has a LGA 775 Socket. It will support Intel Core 2 Quad, Core 2 Extreme, and Core 2 Duo processors with an FSB of 1066 (800MHz). Thus is should support the dual core 775 processors. (Some Pentium 4, Pentium D and Celeron D CPUs may also be compatible with the board.)
I hope this helps.
May 06, 2012 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
CPU fan runs at high speed constantly although temperature only 27 C
the fan can have dust blocking the air way to the mother board take fan off blow out put back see if it sounds any quieter.
Feb 13, 2011 | Foxconn G41MX-F 2.0 Socket 775 Celeron...
ONN N15235 motherboard, which is a 775 socket. I am currently running a Pentium E2160 on its but its pretty slow so I bought an E5400 to replace it. When I changed the CPU over and started up my computer...
The LGA 775 processor socket doesn't matter, calderwooddu.
It's up to the motherboard chipset, and the BIOS program, and version, of what that Foxconn N15235 will support. I would go back to the Pentium Dual Core E2160, use CPU-Z from CPUID.com, (Free), and see what the motherboard chipset is, first.
(Motherboard chipset: The Northbridge, and Southbridge chips. Chip is slang for I.C. Integrated Circuit)
The Northbridge chip is what determines what Processors are supported.
1) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Since the E2160 is built upon the 65nm technology, and the E5400 is built upon the 45nm technology, the Northbridge chip of the Foxconn N15235 may not support the E5400.
With the technology change are also Instruction Set changes. Plus other parameter changes. The BIOS program, and version on the Foxconn N15235 may not support these, either. Sorry to be a bummer.
Not a solution per se, Yet.
Need to know what computer this Foxconn mobo is out of. (MOtherBOard)
OR, if you get the computer operational again, let's use CPU-Z to see what the motherboard chipset is.
Need help in downloading, and/or installing CPU-Z, post in a Comment.
Oct 09, 2010 | Computers & Internet
Cheers'
Mike
Jun 06, 2010 | Foxconn 6627MA-RS2H Motherboard
Cpu support
An attractive value of dual core processors is that they do not require a new motherboard, but can be used in existing boards that feature the correct socket. Check sockets if same then enjoy. I don't think that you motherboard supports Core 2 CPU,but you can't neglect the chances.Before buying ask the retailer about the sockets matching.
Jul 17, 2009 | Foxconn 6627MA-RS2H Motherboard
Computers & Internet Logo
460 people viewed this question
David Payne
David Payne
