Question about Sharp AR-507 Copier
I have a sharp ar-287 error l3 - 00 how to fix?
    President:
  • Sharp Master
  • 990 Answers
Hello sir; Try to make a copy without the cover then you may see the mirrow not moving out, you open the glass to serch the factor it cause this problem.
Posted on Jun 04, 2009
Windows 7 unable to detect Sharp Ar-287
Hi
Verify if your Windows 7 is 32 bit or 64 bit, than download the driver accordingly from the Sharp website. Also try upgrading the driver ,it helps.
Please check this link:-
http://xpdrivers.com/printer/sharp/ar/ar-287/_5_6753.cfm
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 06, 2011 | HP Computers & Internet
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
Error f2-31 en fotocopiadora sharp ar 287
You must your copier TD cartridge,then solve your problem.If you are not fix it,Then press
C>Photo>C>photo>16> start key
Apr 19, 2010 | Sharp AR 163 Copier
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Sharp AR-507 Copier Logo
222 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
