Question about GE Lands Phones
Require manual to program phone numbers in speed dial function
  • 190 Answers
Hi, Please try the following links for the manual http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_telephone_product_list.html http://safemanuals.com/brand-user-guide- instructions-owner-manual/GE%20PHONE http://www.retrevo.com/samples/GE-manuals.html Thank you..
Posted on Jun 04, 2009
Edit and existing speed dial
  1. Press the Function (FNC) button.
  2. Press the speed dial button you want to program.
  3. Dial the number.
  4. Press the Function (FNC) button to set the number.
  5. The message Speed Dial Set (SPD SET) displays, indicating that the speed dial button is now programmed.
NEC telephone user guide Thunderbird School of Global Management IT Help
Nov 10, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
Aug 04, 2017 | NorStar T7316E Corded Phone
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
How do I manually enter phone numbers into the "speed dial" directory of my Toshiba FD-9859 cordless telephone?
Welcome to Fixya
To program a speed dial on your phone, enter programming mode (press #9876 on your phone). The phone will display "USER PROGRAMMING MODE." Press the Spdial button, enter a speed dial number (100-119), 9 plus the phone number you wish to dialed (1-213-555-1212 for example), then press the Spdial button one more time to lock it in. To use a programmed speed dial, just press the Spdial button plus the number.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 06, 2011 | Cell Phones
How can i use the buttons of panasonic kx-t7730 corded phone ?
The 12 buttons on the right can be used for personal speed dial numbers and features like paging. They are programmed by pressing PROGRAM dialing codes and STORE. An outside call would use an "access code" usually "9" plus the number. Paging is 330.
The 12 left side buttons are very valuable as they have lights. You can store lines, extensions, and features that require lighted buttons, such as CID Indication or VM functions. They are programmed by PROGRAM the button a code the feature and STORE. For example, lines are programmed with 0 + line Extensions with 1 + ext and CID Indication System with 96 or the 9x voice mail commands.
Your OM or User's manual has a section on flexible button assignment with the codes and buttons required to do the programming. In my TA-824 200-OM it's in section 3.1.3.
Carl
Feb 19, 2011 | Panasonic KX-T7730 Corded Phone
Speed dialing
There are two types of speed dial and the programming varies with the system you have.
System speed dial is programmed from the operator or manager's phone or PC and they reside in system program 001.
Personal speed dial numbers reside in my system at location 10.
You can try PROG 10 and see what the display says.
The user manual has instructrions for programming personal speed dials.
Carl
Aug 27, 2008 | Panasonic KX-T7731 Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Programming speed dial!!
ARE YOU PROGRAMMING PERSONAL SPEED DIALS, SYSTEM SPEED DIALS OR BUTTONS ON THE PHONE AS SPEED DIALS.
IF SYSTEM YOU MUST BE ALLOWED IN THE PROGRAMMING BY YOUR INSTALLER TO DO THESE UPGRADES. NORMALLY THE RECEPTION/ FIRST EXTENSION ON THE SYSTEM HAS THIS ABILITY. ADMIN PASSWORD IS 1234 PROGRAM 001 IS WHERE YOU PUT IN THE NUMBER AND 002 IS WHERE YOU PUT IN THE NAME
UNDER MANAGER PROGRAMMING, PAGES APPROX 210-215
Apr 28, 2008 | Panasonic KX-T7730 Corded Phone
How to program the phone
Give us more info. What functions do you need? Speed dials Feature 00 Press button to program Enter speed dial number Feature 00
Apr 11, 2008 | AT&T Lucent MLS-12D Phone
Lands Phones Logo
221 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
