Question about Garden
My karcher cleaner does not get the full pressure at nozzle
When I turn the nozzle handle to get the maximum pressure from the nozzle to clean I am only getting around half the pressure I use to.When I twist the handle from soft spray to high the machine the steam coming out goes out to the normal width and if I try to turn it more it seems to get smaller and distorted and not the wide spray.and also loses pressure
my machine is a karcher electric model 350 I think
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
clyde2j2
  • 137 Answers
SOURCE: on my karcher pressure washer, how do i get the
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Posted on Apr 13, 2009
  • 92 Answers
SOURCE: Karcher 2600 (Honda engine) has lost pressure.
Dear Modad,
First one must see if the problem is in the Honda engine or in the pump. So you must try the Honda with no load. You can remove the gun from the pump, but leave the water supply going into the pump. In this way you still have some cooling effect from the water. Now with no load you try the Honda engine. If it is possible tune and set the Honda engine to work correctly. Now if the Honda runs smoothly,...then the problem is in the pump. Regarding the pump try the system by attaching the gun with no NOZZLE/ or LANCE. Open and close the gun to see reaction of Honda Engine. If in this case the Honda runs OK....then attach a NOZZLE so that you have pressure and load. If the Honda starts to die down, this could be that the Honda needs servicing. This like having a car and uphill it will stall and dies down. Here the engine needs servicing. One small thing to look for. I came across Honda driven pumps which have a cable coming from the Honda's carbureter to the head of the pump. When the gun is released the cable is pulled from the head of the pump by means of a piston type valve and this in turn will reduce the speed of the Honda. As you see it is difficult for me to pinpoint the real cause when I do not know the model number and type of pump you have. But if you go by these guide lines you shuld find the fault. Remember...ALWAYS try HONDA ENGINE without load first. I also wish to add that the Honda could be working OK...but then the pump has some problem that it is stopping the Honda. So the pump could also for some reason be jammed and this needs the pump to be serviced. Another hint is very simple. If the Honda is not getting to its maximum power and revs...then the pump will drop pressure.
I gave you various hints to tackle the problem by simple elimination. But you must be able to know how to service the Honda or Pump yourself. To repeat and remind you...check the honda and service the Honda with NO LOAD!! Thyen tackle the PUMP.
Regards,
Fulltech.
Posted on May 24, 2009
  • 72 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • 174 Answers
SOURCE: motor starts and stops
Diagram here
It could be the Overpressure valve is leaking #20
It could be one of the small valves is not sealing #14 and #15
The soap valve could be not sealing #7
I have also seen micro cracks in the cylinder head #8
Good Luck
Posted on Jul 20, 2009
Motor pulses on full power wash
It sounds like you either have a clogged nozzle or one that is too small for your pump. At lower speeds the pump is pumping less gpm. So your unloader valve does not cycle. Then when you go to full power. The engine is running faster and pumping more gallons per minute. The nozzle is too small or clogged and so the bypass opens and closes ( surges) Try a new nozzle that is the right size for your machine.
Oct 09, 2014 | Karcher 2500 PSI Pressure Washer
How do I connect detergent tank to pump? This is a g3000 washer
G3000 is not much help. I have a car with an engine, can you help me get parts for it?
In general it is not a good idea to run solvents and cleaners through the pump. It tends to destroy the pressure seals ( people are often creative in what they use as cleaners) To protect the pump there is usually a siphon fitting on the high pressure side of the pump. There is usually a hose that you stick into your detergent. You then put in a large capacity cleaning nozzle and the detergent is sucked up the hose and out the low pressure cleaning nozzle. When you put on the high pressure spray nozzle the siphon valve seals and it does not draw detergent through the hose.
Oct 08, 2014 | Karcher Garden
I have a Karcher K3000 G Annovi XMV 3G30. The pressure control bar that you turn one way to increase pressure is stuck and won't turn either way. Does anyone know what could be wrong
these valves are preset at maximum pressure rating and locked with a nut inside of handle some have a cap on top increasing or tightening valve for more pressure may not be wise due to the fact that if you over tighten it may not unload causing pump failure. lose pressure is normally caused by either a worn nozzle or seals.
Aug 08, 2014 | Karcher Garden
Karcher paatio cleaner attachment cleaning in suiggly lines
Squiggly lines are sign of nozzles being partially clogged. Try using a needle to clear nozzles. You will need to remove the nozzles to do this. When re-installing the nozzles make sure they are in line with the pressure bar.
Mar 13, 2013 | Karcher KE302007A Classic Series Pressure...
Karcher professional hds 655 steam cleaner not much water pressure
If there is nothing wrong with the machine but you have lost power over the years you have been working it. It could be that the machine needs a new pump kit or/and change the pressure nozzle.
smaller issues could be that the pump isnt turned to high pressure or if you have an servo control on the gun that it is turned to low pressure instead of high pressure.
May 14, 2012 | Karcher Garden
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
When I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
