Question about Jenn-Air JGR8850 Gas Kitchen Range
Jenn-aire gas stove
It takes forever  for the oven to heat up. to get to 375 it takes 45 minutes. What can I do? Or what part do I need? Thank You m elias
  • Anonymous Nov 08, 2007
    jenn-aire electric element went out I replaced with a element from home depot now it takes 45 minutes to get to 400 degrees. the elementd has 19.1 ohms resistance. model # sce30600b
  • 248 Answers
  If this is a gas range your problem is most likely your oven ignitor.  As they get older they get weak and takes longer to open gas valve.  Eventually it won't come on at all.  Replacing the oven ignitor will often take care of problem.  BE SURE TO UNPLUG UNIT BEFORE REPAIR!!
  Remove oven floor.  The ignitor is in a cage attached to back of oven burner.  It mounts with 2 screws.  You may have to cut wires and wirenut in replacement.  Doesn't matter if the 2 wires are reversed.
Posted on Oct 24, 2007
  • Gerald Griffin
    Gerald Griffin Nov 18, 2007
    You need to check for 220 volts to element. If element never gets red hot it probably has only 110 volts to it. Check for a burned wire. Will possibly need a relay board.
It takes over an hour to preheat my gas stove
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jul 27, 2011 | Jenn-Air JGR8850 Gas Kitchen Range
Problem fixed!!! Lowes is giving us a new stove!!!
Oct 08, 2009 | Jenn-Air JGS8850ADS Gas Kitchen Range
I have a jenn air cook stove that was used with propane. I would like to know how to convert it to natural gas
You will need a conversion kit. The kit should be about twenty dollare, and it will explain exactly what to do. if you have any questions get back. You need a Jenn Air kit so go to any Jenn air dealer to get it.
Jul 07, 2009 | Jenn-Air JGW8130DD Gas Single Oven
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
What is part #
Part number for the electronic control panel for your unit is 74008131 and cost is about 160.00 in new. If I can help further, I am here....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Jenn-Air JGW8130DD Gas Single Oven
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Oven is no longer heating
If this is an electric oven you probably need to change the heating element. If it gas check to see if the pilot is lit
Nov 24, 2008 | Jenn-Air Ovens
Oven does not heat up
We may have found it -  google Maytag Gas and Electric Range Service Manual (1997 models to present) and save it as a PDF to your desk top.  Then print out the PDF pages # 18, 25 & 26, 52, 62 65 & 66.  Those pages sound exactly like the problem we're having, which sounds identical to the problem you're having. We now suspect the issue is the gas valve heater coil and the volts it needs for ignition.  Because without enough volts, the ignitor won't ignite (like, duh?).  The specific PDF page is # 66 in reference to the Glow Bar Operation item # 4. If we're right, we'll need to get three small parts, totaling about $60 in all.  Let's hope this is the solution!
Jul 09, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
177 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
