Question about LG RUMOR Cellular Phone
Everytime the backlight would die out, and i push the back button to call or something, it always tell me to unlock it. how do i fix it to where i dont have to keep doing it?
    Problem Solver:
  • 14 Answers
Hey (:
It's just the autokeyguard.
it you push back (like hold it for a while) it'll go
to the main part.
if you want to turn that off..
go to settings
and go down until you find the
autokey guard part.
and turn it off.
now it won't auto lock itself!
Hope this helped!
-Selena
Posted on Jul 08, 2009
Display is stuck in negative effect how do i fix it
Do a hard reset by pulling the battery (if you have access) if not hold down the power button until it turns off. The negative effect you're seeing is really a backlight that is turned off, probably due to low battery, or it has died completely. If turning it off and turning it back on doesn't fix the issue you may have a dead backlight.
Jun 07, 2015 | Tablets & eReaders
Pulled tear drop locking mechanism down but keeps springing back NFW7200TW
it looks like you have a bad door switch and is the easiest and cheapest thing to fix on the washer part number 8182634 and it's around 65 dollars.open the door unplug the washer,remove the spring and pull off the rubber boot enough to get at the door switch,remove the screws pull out the switch and unplug it,put it back together,put some soap on the spring so it will go back on easier.hope this helps,also in the washer there's a tech sheet with all the codes and tells you how to run in diagnostics
Apr 07, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Push the power button. stays on long enough to say digital and turns off.its not the inverter board.
I am currently working on the same problem. There is a simple test you can do to determin for sure that it is not one of the six inverts. Unplug them all. Plug each one in one at a time. Unplug from wall everytime. The tv will backlight even off just one. The tv is turning off due to a safety/protection feature. Once it senses the high voltage the tv will shut off. If you plug one in and the back light will not come on anymore you can fix your tv for $16. Pn/ 3pc0xB001
Oct 29, 2012 | Emerson LC320EM8 32 in. LCD TV
My backlight appears to have gone out. The green light at the top still blinks that I have a message and when I push the power button the 4 icons on the bottom light up. I can answer calls because I know...
this has happened to me before, all that you have to do is remove the battery by sliding off the battery cover and then popping out the battery, waiting 5 seconds and putting it back in usually fixes the problem. good luck!
Aug 22, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I recently had an avital 4103 remote start system installed in my 09 Chevy Silverado truck. The remote starts the truck perfectly everytime however the lock and unlock buttons dont unlock or lock everytime...
As an L1 ASE Master tech I ALWAYS advise against aftermarket alarm systems, however the problem you are experiencing is due to an action that is not being taken by the vehicles control modules. The installer should tie into the door control modules or find out why the body control module is recognizing the command for the locking/un-locking action, (hence the lighting response), but the doors are not taking appropriate action. I would have to look at live data in the vehicles control modules to see what modules are being commanded to do what. Take it back to the place where it was put in and tell them to fix it or refund it.
Nov 21, 2017 | 4103LX Remote Start System with Two...
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
My back passenger door lock will not lock or unlock when all the others work fine...from what i can tell i think it might be a "frozen lock mechanism" because when i push the unlock/lock button it tries to...
It sounds like your lock actuator is dying, or something is jamming up.
If your car is a 2008, then this should be covered under warranty to fix.
If you do want to fix it yourself, you can. On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull back the weather seal and you can access the inside of the door
Oct 20, 2009 | 2008 Chevrolet Impala
Disc won't eject.
When you hit eject do you hear it attempting to push out the disc? It may be blocked by something. If it is not attempting to push out the disc then something isn't registering with the eject button. In this case, power down the wii, unplug all plugs from the back, wait 90 seconds or so, plug in just the power plug and hit the eject button (before hitting power or anything else). If it still does not try to eject then either the button is broken or the disc drive in the wii has died.
It is still probably under warranty from Nintendo, they can fix it for free for you. If anything, give them a call at:
1-800-255-3700
Jun 25, 2009 | Nintendo Wii Console
Sidekick 3 non-stop activation screen
you can push the top left button wen tha activation screen comes on and push customer service and tell them ur problem
Jun 16, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
LG RUMOR Cellular Phone Logo
252 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
