HP Support > Probook 4530S Notebook PC > Manuals > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=5060880#1
Under the bold subheading -
Service and maintenance information -
Click on -
HP Probook 4530S Notebook PC and HP Probook 4730S Notebook PC - Maintenance and Service Guide
Bottom Door - Page 49
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Position laptop bottom side up, Battery Compartment facing you.
3) Remove the Locking Screw if installed.
(Area where Battery Compartment meets Bottom Door, and in the Middle; is screw location)
4) Slide the Bottom Door release latches to release the door.
(One latch on each side of Bottom Door; where Bottom Door meets Battery Compartment. The Latches slide to the INSIDE of the laptop)
5) Slide the door towards the Front of the computer, and lift off.
(Front of computer is AWAY from you. On the opposite side of the Battery Compartment)
Regards,
joecoolvette
[ P.S., you remove the Bottom Door; you wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; or you risk using the laptop for a Frisbee from now on, or a doorstop.
Average cost is around $3 to $6 ]
This is already resolved. Overheating of the laptop has somehow dislodged the processor and the video card (chip creep). After taking out the heat sink on top of these components and pressed it firmly- and replaced the thermal compound and re-installed the heat sink- it suddenly started to work again.Thanks for the inputs anyway.
