Question about Acer Aspire 3680 Laptop
My satellite M55-S331 Toshiba laptop screen went black
I tried powering down the laptop, unplugging the ac adapter and removing the battery.  I pressed and held down the power button for 15 seconds and then plugged the ac adapter back in and powered up the laptop.  Unfortunately I can barely see the screen.  I put the battery back in and still can hardly see anything on the screen.
Any other suggestions?  Can it be the led lights?
Thanks for any help.
  • Anonymous Nov 02, 2007
    Yes, i JUST RECENTLY HAD THE SAME PROBLEM...your problem is totally analogous to mine, did you receive any advice from anyone on what to do?
Cheap soma[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20soma%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]cheap soma[/url] zoloft and pregnancy[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20zoloft%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]zoloft and pregnancy[/url] ultram[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20ultram%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]ultram[/url]
Posted on Mar 28, 2008
I had the same problem, and this article worked for me. Good luck.
http://www.daniweb.com/forums/thread41145.html
Posted on Jan 22, 2008
  • 117 Answers
Bios or time seting problem startup time is very large so that problem
Posted on Nov 07, 2007
Bios no longer detects the harddrive
Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
Jan 14, 2014 | Toshiba Satellite M55-S331 Notebook
Drivers windows xp Toshiba Satellite M55-S331 (PSM50U0HP01V) PC Notebook
try this site
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp
Oct 26, 2011 | Toshiba Satellite M55-S331 Notebook
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Toshiba Satellite Laptop screen went black
You may try this. Unplug ac adapter and remove the battery out. While the laptop is off and without the power sources, hold the power button 10 secs. Put the power sources back and turn it ON.
Mar 10, 2011 | Computers & Internet
Toshiba satellite m55-s139 problem no screen no beep
Hello.
The most common power reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Feb 01, 2011 | Toshiba Satellite M55-S139 Notebook
TOSHIBA SATELLITE M55-S3512 LAPTOP LCD SCREEN is red then it switches off. When I close and reopen the lid the screen turns on for 3 secondes then goes off. Do I need to change the lcd?
hi,
Please try to remove the battery and the AC adapter then press and hold the power button or the on/off button for one minute. Basically,it will not turn on since there is no power supply connected. After one minute, connect the laptop directly to the power outlet without using the battery just for the meantime then power on the laptop, if this will not fixed the problem, you will need to replaced the LCD cable or the LCD itself.
Hope this will help...
Jan 08, 2011 | Toshiba SATELLITE K000080220 LAPTOP LCD...
Toshiba Satellite - black screen only when plugged in
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
Jul 07, 2010 | Toshiba Computers & Internet
Laptop will not boot up after leaving it in hybernation.
please remove the battery and the adapter from your laptop and then press the power button and hold it down for 20 - 30 seconds with both battery and adapter removed. this will remove the residual power left in the laptop and then hopefully your system will be able to power on again and you will be able to switch on the laptop again. This process is called flee power
Jul 12, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite M45 S331 PSM40U-01R001 will not power on
No.. the problem has nothing to do with your battery....
Yes Quite Possibly the motherboard is fried...
Nov 18, 2008 | Toshiba Satellite M45-S331 Notebook
Acer Aspire 3680 Laptop Logo
485 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
