Question about GE Washing Machines
GE 123c8294p001 washer starts spinning and hums and then starts again. It just keeps repeating itself through out the spin cycle. Everything else works fine.
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
It could be anything from a bad belt to a bad clutch to a bad tranny. In my opinion this washer is not worth repairing.
Posted on Jan 09, 2009
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Trouble with the spin cyle.
Bad motor. Easy to replace. Worth the effort.
To find out how, click HERE
Feb 04, 2009 | Kenmore 24982 Top Load Washer
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
How do you reset the washer?
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Lale
Jun 20, 2008 | GE WBSR3140DW Top Load Washer
My washer keeps stopping at each cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.
Jan 24, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washer will not spin
Could be a bad clutch or transmission. I would either call a tech or get a new washer (these newer GE models don't seem to be very reliable, go for a Whirlpool/Kenmore model next time). Here are breakdown diagrams for your washer: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151 Hope this helps, APP Tech
Aug 07, 2006 | GE WJSR2070B Top Load Washer
Washing Machines Logo
330 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
