Microsoft Surface RT Logo
n
nicole smith Posted on Jan 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What to do when your surface RT screen is frozen and the home and power buttons are not working
Its completely frozen and settings ba won't show up at all.
Aaron Fickling
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 65 Answers
  • Posted on Jan 31, 2014
Aaron Fickling
Expert
Level 2:
New Friend:
Night Owl:
Answers
65
Questions
Helped
18469
Points
145
Just let it die then dont use it and just plug it up to charger. should be good to go then
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
How do I shut down my Surface RT
if you do not mind loosing any data press and hold reset button for 30 seconds will set back to factory default settings or snap case open and try cleaning button surface where it connects
Surface RT will not power off
Try pressing the power button down for 15 seconds, then release.
Hiope this works for you.
How do i get my RT to boot
Here are the steps to go back I factory setup. It will remove everything personal you have on the Surface - photos, docs, etc. They will still be in the Share drive if you utilized it for storage.
  1. Restart the device made for Surface.
  2. Press F8 during the initial BIOS post to bring up the Advanced Boot Options screen.
  3. On the Advanced boot options screen, use the arrow keys to highlight Repair your computer, and then press Enter.
  4. Select a keyboard layout, and then click Next.
  5. Type the user name and password of an administrator, and then click OK.
  6. Under System Recovery Options, select Reinstall Windows. This option will restore Surface to the factory image, and any customized user information will be lost.
  7. When the restoration of the factory image is complete, the device made for Surface will restart, and the setup process will begin. This process is identical to the first time you set up Surface; you will be guided by a series of prompts and dialog boxes.
One more note - if you deleted the restore folder to save drive space this will not work. You'll need to take to tech support.
Good luck.
Surface tablet froze while using and nothing works won't power off or anything
Hold the power button down for 10 seconds. Then turn it back on.
1helpful
Frozen screen
Force it to shut down by pressing the power button down for 10 seconds, then release and turn on again.
Frozen Screen
Pull the battery and wait 30 seconds to reinsert... then put it back in and hook up to ac adapter and power it up... it should reboost with no problem... this problem shouldn't recurr after proper updating of windows software. Post results
Frozen tab2 10.1 samsung
Try this lol,
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
If you want see the video, you can visit my blog
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
3helpful
2answers
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
Top Microsoft Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
