Question about Joy Satellite M105 S3031 Laptop
Toshiba Satellite M105 screen display issues.
Hi I have a Toshiba laptop (Satellite M-105) and I just started having screen display issues. The screen will get a fine micro grid over it (washout) and lose some color brightness. If I hold the top corners of the screen and gently push on the right side(twist), it goes back to normal. I've checked the connectors to the inverter and other stuff(via a disassemble), and they're good. SO WHAT IS CAUSING THIS? Please and Thankyou for your help.
White 1 in. Bar running from top to bottom of screen
Plug in external monitor to see how that works. If it does same the issue is with your laptop. If it works fine the issue is with your laptop display that needs replacement.
Aug 31, 2017 | Toshiba Satellite M65-S909 (PSM60U02W021)...
Hi, I have Toshiba Satellite A305 S6905 model.
It is more on a hardware issue. The battery needs to be drained. Once on, let the battery drain and re charge it for 4 hours.
Oct 29, 2013 | Toshiba Satellite A135-S2386 Notebook
How to replace LCD panel on Toshiba Satellite M105-S3004 Notebook?
Plastic Display Bezel is not as simpy as you think. It is made of space-age plastic.
Procedure is the same as for a Satellite M110 series, and M115 series Notebook PC,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M115/remove-inverter-replace-lcd-screen.htm
Just to add;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm
After the Screw Covers are removed, and the screws, from the Display Bezel, the Bezel can be 'popped' off.
The Bezel has plastic protrusions, or tabs, extruded from it's plastic frame. These tabs snap into place in the Display Cover. (Top cover of laptop)
There are tabs formed on the inside edge of the Display Cover, that the tabs from the Display Bezel, snap into.
When I started years ago, I used a guitar pick to ease the Bezel up, so I could get my fingertips under it. (OUTSIDE edge of Bezel. Not inside edge where the LCD screen is)
Now I don a set of anti-static gloves, and ease the inside middle edge of the Bezel, (LCD screen side), up. Then I start working towards one corner, until this portion pops free, and then I go towards the other corner.
Once you work a side loose, and the bottom, the rest of the Bezel starts popping free.
Although the Display Bezel looks to be flimsy, as stated previously it is made of a space-age plastic. Pretty tough stuff, really.
Just go slow, and use care.
When you hear the tabs pop up for the first time, you may think you have broken something. Nope.
Just wanted to state to ease your mind.
Make SURE the LCD screen you are purchasing is THE correct one.
An LCD screen, and the screen Inverter, are a MATCHING pair.
Crossover the manufacturer name, and model number on the back of the LCD screen, to the new one.
Or go with the LCD screen replacement manufacturer's information. B
If so, be sure there is a Return option, if the new replacement LCD screen proves to be the wrong one
[ An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Some of the newer LCD screens use LED lights for a Backlight.
The Toshiba Satellite M105-S3004 Notebook PC, uses a CCFL for a Backlight)
A screen Inverter is used to convert the electricity (Power) from the laptop, for the Backlight, and the LCD screen ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 04, 2012 | Toshiba Computers & Internet
I need VGA drivers for Toshiba satellite m 105-S1021
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Apr 29, 2011 | Toshiba Satellite M105-S1021 Notebook
My satellite toshiba laptop shows a screen of fine colorful lines
did you ever try to go on gateway site to find a fix or microsoft.com to see if there is a update display driver for you computer
Feb 10, 2010 | Toshiba Computers & Internet
Verticle lines on the screen
Failing Display Panel Circuit Board... THis Means You Will Need A Screen Replacement..
Nov 17, 2009 | Toshiba Satellite A105 Notebook
Satellite M105 S322 Display very Dim. The PC works fine with external monitor but the LCD display is dim and cannot see anything on the screen
You have lost your backlight which is a thin long bulb built into the bottom of the screen itself. You have the option of getting the backlight by itself and rebuilding the screen or buying a new screen assembly and changing that out. Below is the service guide to change the screen.
Below is a general guide for display problems....
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Oct 27, 2009 | Computers & Internet
Screen Issue
I would check to see if the RAM has become loose, if you can reseat the RAM. Do you hear any beeps when nothing is displayed?
Aug 18, 2009 | Toshiba Satellite M35X-S161 Notebook
Replacing lcd on toshiba satellite m150 notebook
Here is tutorial on how to change the LCD on a M115 which is similar to the M105:
Toshiba Satellite M105. How to take apart notebook.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Toshiba Satellite M105-S3021 Notebook
Joy Satellite M105 S3031 Laptop Logo
303 people viewed this question
Top Joy Computers & Internet Experts
john h
Andrew Taylor
Andrew Taylor
Marlin
Are you a Joy Computer and Internet Expert? Answer questions, earn points and help others
