Question about Samsung Digimax S500 Digital Camera
Battery the battery indicator is low, pictures will not transfer; I put new batteries in and the indicator stays the same.
Did you try the reset?
there is a reset function somewhere in the menu
Posted on Oct 25, 2007
My proofcam wont take pictures, new bats red light stays on doesn't blink like other one does. Help
Have you tried swapping/exchanging batteries with those that works; maybe you should try this option first and see what happens.
Chances are your new battery is defective or that your camera needs to be serviced or repaired (motherboard defective/component failure)
Red light indicates low/drained/incompatible battery; as such no pictures will be taken/captured
Oct 12, 2017 | Televison & Video
4x4 low light on car will not move
The electronic module (located behind the glove compartment) controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS. Do you know what DTC'S Are ? Diagnostic trouble codes !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short Circuit to Battery GEM GO to Pinpoint Test C . P1812 4WD Mode Select Circuit Failure GEM GO to Symptom Chart. P1815 4WD Mode Select Short Circuit to Ground GEM GO to Symptom Chart. P1820 Transfer Case CW Shift Relay Coil Circuit Open or Short to Ground GEM GO to Pinpoint Test B . P1822 Transfer Case CW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Electric Clutch Relay Short to Battery GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Circuit Failure GEM GO to Pinpoint Test B . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test B . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test B . P1850 Transfer Case CONTACT PLATE "B" Circuit Failure GEM GO to Pinpoint Test B .
P1854 Transfer Case CONTACT PLATE "C" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1858 Transfer Case CONTACT PLATE "D" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1866 Transfer Case Maintenance Required (GEM Only) (4-wheel drive operation can be restored by clearing the DTC and cycling the ignition.) GEM GO to Pinpoint Test B . P1867 Transfer Case Contact Plate General Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1874 Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Symptom Chart. P1875 Automatic Hall Effect Sensor Power Circuit Short to Battery (GEM Only) GEM GO to Symptom Chart. P1891 Transfer Case Contact Plate Ground Return Open Circuit GEM GO to Pinpoint Test B Your best bet , take it to a qualified repair shop
Apr 04, 2017 | 2002 Ford Explorer
My 99 expedition won't stay out of all wheel drive I changed the transfer case motor and now it stays I awd for about 10 minute then kicks back out and then the 4x4 light flashes and then it is ok until...
The 4X4 system on your vehicle is computer controlled , GEM module . generic electronic module . The four wheel drive mode switch is a low voltage input to the GEM module . The GEM energizes relay's to control the mode as depicted by input from the mode switch an torque on demand relay an someother inputs . Probably has DTC - diagnostic trouble codes stored in the GEM module .
Transfer Case -Automatic Four-Wheel Drive (A4WD) The automatic 4-wheel drive transfer case system consists of the following:
  • automatic 4WD indicator light
  • brake pedal position (BPP) switch
  • torque on demand (TOD) relay
  • front output shaft speed sensor
  • generic electronic module (GEM)
  • 4WD high indicator light
  • 4WD low indicator light
  • 4WD mode switch
  • rear output shaft speed sensor
  • shift position sensor
  • throttle position output (TPO) from the powertrain control module (PCM)
  • transmission range sensor P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure GEM REFER to Section 413-01 . P1806 Transmission 4-Wheel Drive High Indicator Short Circuit to Battery GEM REFER to Section 413-01 . P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure GEM REFER to the Symptom Chart. P1815 Transmission 4-Wheel Drive Mode Select Short Circuit to Ground GEM GO to Pinpoint Test C . P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test B . P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit to Battery GEM GO to Pinpoint Test B . P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit to Battery GEM GO to Pinpoint Test A . P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test B . P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit to Battery GEM GO to Pinpoint Test B . P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Pinpoint Test A . P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Pinpoint Test A . P1838 Transmission Transfer Case Shift Motor Circuit Failure GEM REFER to the Symptom Chart. P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure GEM REFER to the Symptom Chart. P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure GEM REFER to the Symptom Chart. P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure GEM REFER to the Symptom Chart. P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure GEM REFER to the Symptom Chart. P1866 Transmission Transfer Case System Concern - Servicing Required GEM REFER to the Symptom Chart. P1867 Transmission Transfer Case Contact Plate General Circuit Failure GEM REFER to the Symptom Chart. P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Pinpoint Test A . P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short to Battery GEM REFER to the Symptom Chart. P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit GEM REFER to the Symptom Chart. P1892 Trans. Automatic 4-Wheel Drive 4X4 Mechanical Lock Output Circuit Failure GEM GO to Pinpoint Test B . P1893 Trans. Auto. 4-Wheel Drive 4X4 Mechanical Lock Output Short to Battery GEM GO to Pinpoint Test B .
  • Your best bet , take it to a qualified repair shop .
Feb 26, 2018 | Cars & Trucks
Is the red light indicator ment to stay on all the time when playing, or is this a warning light to let me know that the battery is low .Thanks and kind regards Neil
Simple test to try: Put in a brand new battery... If light goes out, then it is a low battery warning.
HOWEVER, it is likely a warning that battery is on so you don't forget to turn it off when done. Tried to find manual for it and could not. Your manual should tell about it.
Mar 14, 2011 | Ovation MM68-CCB Acoustic Electric...
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
Low battery indicator, even after a new battery
You probably have a dead cell in your replacement battery. Camera batteries have a limited number of charge cycles, and this is not a rare issue with "aged" batteries. Also, when you get a new battery, buy a genuine Canon replacement and not one of the el-cheapo Chinese copies available online. In camera batteries, you really do get the quality and performance you pay for!
Jun 27, 2017 | Canon Photography
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Pentax AX-7 does not take picture
If you just put in standard AA batteries, they do not have enough power to drive the camera. Use high power ones, or better still 2300 mAh or 2500 mAh rechargeable batteries
Aug 27, 2017 | Pentax ZX-7 QD 35mm SLR Camera
Samsung Digimax S500 Digital Camera Logo
65 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
