I have a Bizhub 200 that I used to be able to access the configuration page for by typing it's IP address into my browser (IE7). Suddenly, I can't get to it anymore; I get an HTTP 400 Bad Request error. Any ideas what gives? Some kind of stealth update to IE or Windows, maybe?
I've been having this exact problem with a C351 and it was driving me nuts... no solutions on the internet that I could find so I started investigating further to find something quite interesting... I ran a packet sniffer to capture the data from a browser that worked, and one that didn't. I then telnet'd to port 80 on my machine and manually sent the HTTP request commands. So, the culprit line on my browser sent:
Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/x-ms-application, application/x-ms-xbap, application/vnd.ms-xpsdocument, application/xaml+xml, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Now, this was amazing... I'd remove 1 of those entries, and suddenly it would go from this:
HTTP/1.1 400 Bad Request
Content-Length: 15
Content-Type: text/html
400 Bad Request
To:
HTTP/1.1 200 OK
Set-Cookie: ID=ced917a359fbbe9c98d2dbf444eb034a
Content-Length: 703
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN">
<HTML lang="en">
<HEAD>
<TITLE></TITLE>
<meta http-equiv="Expires" content="0">
.... (more continued)
So I ran the registry editor on my computer, went to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Accepted Documents, saved this to file, and removed one. I had application/vnd.ms-xpsdocument which I wasn't too worried about so I removed it (I can restore it later should I need it). Sure enough, no the Minolta page loads absolutely find on my internet explorer. You may have to remove more than one entry as the next paragraph will explain why I think this is occuring.
I *think* that the "Accept:" line is too long and the built-in web server doesn't like it. That's my guess. I can remove ANY application/ and suddenly it works. I was easily able to remove 1, if this is an issue with a line problem you may have to remote more than 1 accepted-document. I don't recommend removing any image formats!!!! Also, like I say, backup that key first.
I hope this helps,
Shawn
Posted on Mar 24, 2009
After reading through a ton of message boards and seeing a similar problem before, I came up with this and it has fixed my problem on several different machines.
First you need to download and install JAVA. It's free on sun.com
Next you need to remove the following reg key.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Accepted Documents\xps
(should say application/vnd.ms-xpsdocument)
Once done, open up internet explorer and type in the IP address of the copier. You should be good to go.
Posted on Apr 20, 2009
With Java version 5.0 I get the same http 400 error. With the latest version, no problem at all.
Posted on Feb 19, 2009
Ran into same problem. Fired up a laptop that hasn't been updated in a while and the pages loaded perfectly. Definitely an issue with one update. Has Konica-Minolta said anything in re to this?
Linus
Posted on Nov 03, 2008
The issue appears to be associated with .NET framework 3.0. Does anyone know if there are any firmware updates to correct the issue?
Posted on Oct 23, 2008
I am almost positive it has to do with one of the Windows Updates, but can't seem to narrow down which one
When I last reinstalled my system, prior to all the windows updates being applied I was able to access my 350 fine. Then, just like my previous system, after I installed all the Windows Updates, I would get the 400 Bad Request Error.
Called my dealer and they have no idea.
Posted on Mar 25, 2008
Had the same problem. Installed Firefox and it's working now.
Posted on Feb 22, 2008
The assigned IP address and subnet mask displays.
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console#
Before you can assign a static IP address to
the switch, you must obtain the following information from your network
administrator:
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
Nov 26, 2012 | Computers & Internet
Sep 19, 2012 | Dell PowerConnect 3548
Aug 11, 2012 | Computers & Internet
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
Feb 08, 2011 | HP LaserJet 1320 Printer
Nov 06, 2009 | Computers & Internet
Mar 23, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Dec 27, 2007 | Cisco 2501 Router
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
2,895 people viewed this question
Having similar problem except we have a bizhub C550 and the page comes up blank.
The same problem with Bizhub 350 and 250
PC is on the same physical LAN as the Bizhub, no firewalls, routers, etc.
It appears that this problem occurs only if MS Office is also installed on the PC
I have the same issue...http 400 bad request. I am using IE6 and all of a sudden it just stopped working. It seems like it has to do with a Windows update...but I can't figure it out! Help???
Actually, lately I've come to believe it has something to do with the Java 6 updates. But we just traded in all our Bizhub's for Xerox WorkCentres, and have no problem accessing them.
We have a Bizhub 250 and are having problems accessing the web interface as well...
Have the same problem with bizhub 350.. now all of a sudden , we cant access pagescope web connection. we cant use the scanner now. does minolta have any workaround or solution with it?
i think its the windows update.
