Question about IBM ThinkPad T22 2647 Notebook
IBM T22 Battery won't charge & is not detected
My T22 will not charge the battery or even recognize that it has a battery (power mizer says battery is unknown). Have replaced the battery and the motherboard & tried 2 power supplies. The battery indicator led flashes yellow indicating a discharged battery. Any ideas?
  • Jack236 Oct 24, 2007
    Thanks Viri.  I suspected that, but the charging circuit is on the system board which I have already swapped out.  Same symptom with the new one.  The correct voltage seems to be coming through the power jack but I'm not sure of the current.  Since this is the only original part between the power brick & the battery, could that be the problem?  I smelled some smoke about when the problem started but couldn't find anything obviously damaged.  IBM's troubleshooting guide led to the system board, but how likely is that same fault to exist in a new one?  Was sent the wrong board at first which did charge the battery but still could not detect it or it's charge state.  Will double check the charging circuit solder joints & maybe try some Stabilant 22 in the jack connections.
  • Jack236 Feb 08, 2009
    Turns out I received 2 bad batteries from the vendor. The third one worked. Apparently there is a circuit within the battery that identifies it as being a "genuine IBM" battery. If it doesn't read correctly the T22 will refuse to recognize that there is a battery installed.
Put the new battery in and restart windows...this worked for me
Posted on Feb 07, 2009
    Problem Solver:
  • 17 Answers
Take it to a very good technician who will open it up and check a dry joint in the charging system.  Sometimes if you donot attend to it quickly you may find your T22 refusing to power at all with the AC Adaptor.  Delicate soldering may solve your problem.  Power may not be getting to the charging circuit and the battery thus it is totaly discharged.
Posted on Oct 24, 2007
I was given ThinkPad 2647 T22 and it has been in it's case for 1 year. I plugged it into the AC adaptor and the green indicator light came on that the battery was charged after 5 hours. When I pushed the...
Remove the battery and try to power on without it. Replace the battery if the computer powers on. If not, the motherboard have to be repaired/replaced.
Aug 15, 2010 | IBM ThinkPad T22 2647 Notebook
IBM T22 laptop can't get it to start and not battery or charger.
What may have happened is that your power supply may have malfunctioned. I would try to plug another cable (new and functional) just to deny that this is the problem.
Nov 11, 2009 | IBM Thinkpad T22 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
My IBM Thinkpad T22's battery doesnt last. can i fix that?
Basically you need a new battery. Recharageable batteries have a finite number of charge and discharge cycles and they lose their full charge capacity as the get older. The batteries will have less capacity over time ie less available battery time, and when it is worn out, it won't charge at all.
May 15, 2009 | IBM ThinkPad T22 2647 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
My T22 unable to start
Hi Yamato,
It is possible that the battery has been so depleted that it gobbles up all the power from the charger/adapter and leaves nothing for the laptop to use. Perhaps what you can do are:
1. try and charge the battery at least overnight with the laptop off;
2. use the adapter/charger only and remove the battery from the laptop.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | IBM ThinkPad T22 2647 Notebook
Battery/Power Issue
Cant help with the "cheap bastard" part, that is for your own edifcation. Anyway, have you adjusted your laptop power/battery settings. If you have tried changing your settings to "Max Battery", and it is still doing this it is probably a hardware issue between the MB and the battery interface. Thus the second part of your message might be comming true. Sorry.
Aug 20, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
599 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
