Question about Sony Cyber-shot DSC-T300 Digital Camera
Error formatting memory is displayed when camera is on
How to solve the problem of error formatting memory stick
Hey! I've had the same problem, and all you have to do is go to the "format" menu of your camera and click on ok when it says that all data on memory stick will be erased. The message will then disappear. Only problem, if you havent saved your pics yet, you'll lose them.... :(
Posted on Jun 11, 2009
  • 93 Answers
Hi
try to format your memory stick using the card reader in your pc..
it will help your more..
have a nice day
-rajkumar
Posted on Jun 04, 2009
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or...
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 09, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Cannot get my memory stick to work in my camera. The only memory I have is the 'internal memory' which is good for about one minute and possibly 10 photos. How do I get the memory stick of 1GB to start...
Did you formatted memory stick in camera?
Insert memory stick in camera and Format it by going into setup menu, you will see Format option and this will solve the issue.
If problem still not solved and camera gives memory stick error then try another memory stick in camera, you can use up to 2GB memory stick in this camera.
Thanks.
Oct 24, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Format error displaying on screen when i turn on camera,
Format error,
Press menu in camera and select Format in list to format memory stick, click OK.
Problem will solve.
Jul 04, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
C:13:01 Format error
don't worry.i got the solve this problem.because all this happened due to the old files on memory card which corrupted automatically.so you need to format the memory card.then insert the memory card on digital camera.your camera will work finely.
Nov 06, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Format error
i have orignal memory stick but i am also getting same error.. have forated stick on camera but no effect on error. so plz can u tell me how can i format my memory stick ... SONY GURU
Jun 07, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony cyber-shot dsc-s30
try a different memory stick, if no problem with the new stick, use a pc to run a quick format on the old memory card... should solve the problem.
May 01, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Oct 22, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot DSC-T300 Digital Camera Logo
112 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
