Question about Dryers
Hotpoint CTD00 trips the power
Our dryer was working just fine until 2 days ago I switched in on and it tripped the switch and the fuse board and tripped out a lot of other stuff. It does this every time - any ideas please?
  • braved Dec 05, 2007
    Brilliant - thanks
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
Posted on Dec 05, 2007
I have been having the same problem as a couple of other people here with my CTD00 tumble dryer blowing the fuse in the house, i initially thought that it was due to the fact that it was being used in the garage which itself is quite cold and damp.
So i brought the dryer in the warm and left it for a couple of days to try and dry it out before taking the back off, and this made no difference.
So i eventually got round to taking the back off to try and ***** how damp it was, it turns out that this was not the problem at all. The problem was that there was an under wire from a bra in the back of the unit which was causing a short across the heating elements which then caused the electric in the house to blow.
This has now been removed and the dryer is working fine.
You will still have to take the back off to identify this though.
Posted on Jan 31, 2010
If you look where the 2 tubes on the right hand side go into a container ( not sure its name ) there is float in the bottom part where if there is too much water if sets of a sensure which trips the switch.I dry out water with tissue and a hairdryer , working again.
Adrian.
Posted on Jul 15, 2008
  • adrianmurray Jul 15, 2008
    It was working for about 20 mins ,apologies , tripping again have gone through everything any ideas?
I had the same problem after it tripped the fuse i looked in the dryer where the cloths were and saw that there was a buildup of steam in the drum. i then realised that because i was using the dryer in a very cold outhouse in the winter the water in the cloths was condensing too fast for the machine to process, this in turn caused a a backup of steam in the drum which backed up so much that the heating elements shorted out and caused the fuse to trip out. i hope this helps. after moving the dryer to a warmer part of the house i have had no problems.
Posted on Dec 08, 2008
Our Hotpoint ctd00 keeps tripping the fusebox, we
Disconnect the heater thermostats by poulling a wire off each stat, and then try it, if it still trips, then could be faulty motor.
The stats are located at the rear of the dryer, behind removeable cover.
Mar 25, 2010 | Hotpoint Dryers
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Safety Trip
On the heater there will be a cut-off switch with a small hole where you can stick a needle in until you hear a 'click'.
Jul 14, 2009 | Hotpoint Dryers
Every time I turn the dryer on it trips the electric. do you know where the switch is to stop this on my hotpoint ctd00 dryer
sounds like the element is gone short curcuit . if the power did not trip it would go bang so be careful .these things can be dangerous .have known the cabinet to be live when earth not conected in the plug...farr64
May 08, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Our dryer is working fine until it trips the switch.
If tripping of the switch means the circuit breaker is tripping, then yes, the problem may be in the heater box, or may be the motor. It could also be some faulty wiring though, and a good tech could easily determine what is causing the failures.
Jan 24, 2009 | Roper REX4634KQ Electric Dryer
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Dryers Logo
1,639 people viewed this question
Top Dryers Experts
Marvin
Marvin
