Question about Toshiba Computers & Internet
My toshiba tecra keyboard doesn't work - Toshiba Computers & Internet
  • 674 Answers
Keyboar doesn't work? check the keybaord cable maybe loss only. otherwise check the driver of program for keyboar in your system...
Posted on Jun 05, 2009
Toshiba tecra r850 keyboard problem my notebook key board doesn't work
Hi, make sure the drive keyboard is right and do the update, if problem persists have to replace the keyboard.
Dec 16, 2013 | Toshiba Tecra R850 Series Black Notebook...
Toshiba Tecra A8-S8414 keyboard
I'm not sure if it is worth ..but you can get a new keyboard and change it ..To change the keyboard you have to remove teh hinges cover ..remove the screws and slide the keyboard one inch toward teh display ..and lift it up ..pay attention cause it has a ribbon attached on the motherboard and it is sensible
http://www.uspcparts.com/toshiba-tecra-a8s8414-keyboard-p-9904.html
Dec 22, 2011 | Toshiba Tecra A8-S8414 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
Toshiba tekra 8100 on off knapp var finns den ?
> on off button where finds it?
The ON/OFF could a switch that "slides" about 50 mm,
or it could be a button with an 'I" inside a "circle".
The pictures at:
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-8100/Tecra-8100-FL-inverter-big/remove-replace-FL-inverter-00.jpg
and:
http://www.pcarena.hu/pricelist/oriaskep/toshiba-tecra-8100-570.jpg
do not show any "button" on/near the keyboard.
The picture:
http://www.recycledgoods.com/images/s_p_12957_5.jpg
does not show any button on the back.
So, look for a "slider" or a "button" on the side(s) of the case.
Nov 25, 2009 | Toshiba Tecra 8100 (p000279550) Keyboard
HOW TO REPLACE A TOSHIBA TECRA M4 KEYBOARD
Go to the Toshiba website and the will give you a pdf of the directions. Just let them know what you are looking for...
Aug 31, 2009 | Toshiba Tecra M4 Keyboard
I have toshiba tecra model, some keys on keypad are not functioning .. pls advise .. By Renuka
if u have fall something like water or juice then u have to dissasseble ur laptop keyboard and clean the carbon points of ur keyboard using Aciton with tishue but if this not work then u have to change ur keyboard
hopw this will fix ur keyboard
Jul 30, 2009 | Toshiba Tecra A9-S9021V Notebook
Toshiba techra 9100 laptop
Probably you must open the case, much work and hard the first time...
situated under the keyboard, usually and perhaps an antenn-wire to somewhere--
Apr 11, 2009 | Toshiba Tecra 9100 Notebook
Tecra m7 doesn´t boot up
mine does the samething have you found out what the problems is yet?
Dec 23, 2008 | Toshiba Tecra M7 Tablet PC
Computers & Internet Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
