My dryer make a loud squeal noise and sometimes strappy clothing article get caught and I can't find any shard edges.
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
SOURCE: squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
SOURCE: Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
SOURCE: Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
