Samsung LE40R73BD DTV freezing, wont chnage channel
Hi I have the a 40 inch LCD Samsung LE40R73BD
Whenever the TV is on DTV setting, to obtain freeview channels, the channel is stuck.  Its on one channel, when first switched on pictures and sound work, will not move from this channel and can only get into certain menus, eventually picture freezes and only sound works.
ANy ideas
  • 2 more comments
  • freakin Dec 15, 2007
    I have the same problem also
    Did you manage to sort it?
  • Anonymous Mar 14, 2008
    Another person with the same problem here! Anyone know a fix for it yet?
  • pddp Apr 30, 2008
    same prob here......
    I've tried going thru the plug and play setup to try & "reset" the DTV but no joy I just end up with a black screen.
    Anyone help...........please :(
  • simonjterry Nov 10, 2008
    i have the same prob tried the info menu mute this only switches tv on off then back on again?no menu apears?
I've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
  • 2 more comments
  • herriesco Jul 12, 2010
    this sorted out my freezing problem on a samsung flat panel tv - very usefull
  • pgut1 Jan 04, 2011
    I have a SAMSUNG LCD TV LE32N7 and my DTV freezed on one Channel, too. I did RESET like explained above and it worked. Thanks
  • wendy658 Feb 05, 2011
    Excellent, worked for me, thought i might have to renew TV. thankyou
  • LMJ1 Jul 18, 2012
    I followed the instruction, however it the select / OK button does not seem to work. I try to select the reset option and await for it to turn itself off etc but nothing happens :0(
    New Friend:
Hi there i can not recieve any freeveiw channels how can i tune it in when on settings it wont let me go on to the antenna setting for tuning in dtv
Posted on Jan 07, 2011
SOURCE:
HI MY SAMSUNG MODEL LE40R73BD S IS CLICKING ABOUT 5 TIMES BEFORE THE PICTURE COMES ON I DID READ THAT SAMSUNG WILL FIX FOR FREE BUT IS THERE ANYTHING I CAN DO TO STOP THIS, ALSO I HAVE MOVED AND SET UP THE...
This is a common problem with this model and typically due to failed capacitors in the power supply Karen. More info:
Repair Article: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Replacement caps: http://www.electronix.com/television-repair-capacitors-c-16_68.html
Oct 11, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Samsung le40r7 dtv cannot access d.menu. channel freezes on screen.
my tvs saying no signal and ive tryed the source button when i was watching freeview it com up with a system update and nothink happend and now says no signal
Sep 14, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
Freeview
go to menu settings, channel settings, set tv to CATV for cable, AIR for analog, or HD for high def.
Make sure you have the correct cables depending on your connection
Sep 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I HAVE A SAMSUNG LE40R7, I CANT GET DIGITAL CHANNELS ON IT ?
I TAKE IT YOUR WATCHING YOUR SKY BOX OR CABLE ETC THOUGH THIS TV..BUT YOU CANNOT NOT GET FREEVIEW..CHECK YOUR ARIEL PLUG GOING INTO THE BACK OF THE TV, THEN TUNE THE TV IN FOR DTV. NOT CABLE OR SKY ETC THEY WILL NOT NEED TUNED IN..THE MENU FOR DTV..IF THAT DOES NOT WORK..DO ALL THE OTHER TVS WORK OFF THE SAME ARIEL ON THE ROOF TO GET FREEVIEW ???
Nov 14, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
1,445 people viewed this question
Top Televison & Video Experts
Ekse
