Question about Brother DCP-110C All-In-One InkJet Printer
Brother DPC- 115C
New ink cartridge inserted according to instructions. will not operate
  • 7 more comments
  • Kayaking mad Nov 03, 2007
    Have a 115c and when I replaced the black ink cartridge the machine says its still empty and wont print. I replaced the cartridge several times and correctly. Ive also replaced the cartridge with a genuine Brother one and its still the same......HELP
  • kizza Nov 05, 2007
    hi i just got new ink and pink, yellow, and blue ink is working but the black ink isnt and ive tried to test it but still wont work
  • antman1964 Nov 06, 2007
    Almost...
    Ive used generic cartridges and refills before without problems. However this time, when the printer says 'Install Cyan' I do what Ive always done but it simply says 'No cartridge' when I close the cover. Ive taken all the cartridges out, unplugged it, swore at it, kissed it.... nothing works! help me please! Im trying to do my homework here!!
  • Robynrose Nov 20, 2007
    I am having the same problem. Have replaced a new cartridge and it keeps coming up no cartridge despite trying several times. Pleeeeeeze help as I need to get some important papers printed ASAP
    Cheers Robyn
  • Kayaking mad Nov 26, 2007
    Switching on and off doesnt work. Doesnt show an error message just says near empty black....................when Ive put a new cartridge in. HELP!!! Could it be dried up ink in the jets???? if so what can I put in to clean?? dont know what Im on about here, jusat clutching at straws!
  • sjhendo Nov 30, 2007
    Our Ink cartridges have all been replaced and it still says to replace them and will not print a thing!!!!
  • Anonymous Jan 07, 2008
    I am getting "Ink empty" on all of my cartridges.... there is ink in all of them! I have done everything suggested in the instruction book, on the Brither website and on this website. What was that note about a faulty ink sensor? Is that a technician fix?
  • hshh Mar 21, 2009
    i replaced all ink car.
    all the time i get a not that the ink empty cyan
  • Anonymous May 26, 2009
    i have a problem in my DCP350c, the message appearing that this is no cyan and black cartridges installed.. but all cartrigdes are thier... what can i do.? when idis connect the printer and turn it on again it is message that the printer is no cartrigdes installed.. Plzzz help me
  • 832 Answers
What error does the machine show up?
Plz give some more info in detail!!!!!
Posted on Oct 25, 2007
  • Mix-it-up
    Mix-it-up Dec 05, 2007
    PROBLEMS WITH INK DETECTION
    There are many people who have trouble after changing one or more ink cartridge(s). Here are some hints how to fix them:
    • No cartridge
    • Empty cartridge
    1. Take the cart out and reinsert it. Make sure that the cart is well placed and secured.
    When useing generic ink carts (3. party maufractures) the seating sometimes will be difficult because of the different construction of the cart vs. the original ones.
    2. The machine had warned about a NEARLY EMPTY cart. User has changed the cart at that moment and shortly after get a NO CARTRIDGE or EMPTY CART. warning.
    In most cases the user has ignored the demanded reset of the machine which is displayed on the LCD. Machine actually asks for the changing and needs an answer YES or NO. This will reset the ink counter to zero so that the cart is recognized as full.
    BTW: The Nearly Empty warning is just a reminder! You'll waist ink when changing at that moment, because there is more than a quart of ink left inside. Always print until machine stopps by it self and gives the EMPTY message. After replacing machine will continue to print on (and the pc-error will disappear, too)!!
    3. Sometimes there is/are some other cart(s) which are empty, too and wont be displayed on the LCD. Make sure that all carts have a rest of ink inside by taking them out and have a good look at the cart fuelage.
    4. If the error wont disappear unplug machine from power outlet. Take all carts out of the holder, get machine back to power and wait until machine demands carts. Reinsert carts and give the right answer if you are asked by machine. Set date and time!!! Otherwise the machine will always do a large cleaning when powering on (and waist a lot of ink!).
    5. If this wont work there might be a defectiv ink sensor or the small circuit board of the ink detecting sensor -which is part of the holder- is out of position. The latter one happens when the carts are forced into position (mainly due to generic carts!).
I had a similar problem, kept saying Magenta & yellow empty when not.
took all cartridges out, unplugged & restarted, the printer then asked for each cartridge to be installed, did this in turn, after this it asked me if I had changed each cartridge, answered Y to all.
It did a bit of a clean then was OK
Posted on Feb 06, 2008
I have had this problem once again after inserting a new black cartridge and once again I turned my computer and printer, which are plugged into the same box, off at the wall and it worked. Maybe turning the puter off too makes a difference who knows? I don't as I'm the original puter bimbo.
I have same problem. It started off as empty ink and low ink so I replaced first the black, did a test print then even though the other one yellow was still unchanged low the test print came out as black fine, cyan fine but yellow and magenta blank. Because it was blank and reading low I changed the yellow anyway but its still blank. After lots of tests and cleans magenta and yellow still remained blank. Now the cyan is near empty and the magenta even though nothing has been printed. I took them out many times to see if it will get it working tried all the above suggestions and anyway its now started saying no cartridge. I'm not using orig brother ink and don't expect it to be as good but not to print some colours at all is a bit odd. Cant get round this no cartridge thing though, machine has hardly been used so I'm disappointed if its had it.
Posted on Dec 21, 2007
Yaaaaay I got it. Turned puter off at the wall and when I turned it on it had righted itself. Hope this helps others
Cheers Robyn
Posted on Nov 20, 2007
Ive got the solution...........Bin it and buy another printer..NOT a BROTHER! It worked for me!! Even thought it warned of low ink it wouldnt print at all. I stripped down the machine as best I could and cleaned out the ink tubes with a cleaner specifically for the job. Put it back together and it still didnt work. I should have saved my money and not bought the solvent.
So........just buy another printer, after all there a lot cheaper now!!
Posted on Dec 07, 2007
I have brother DCP-115C printer i put new ink catriges and try to print the printer give me a message '' near empty mgent ''what to do ?
This message is printed because the ink of mgenta color is missing or cartige is running out of the ink. If u have put new inks then check whether they r inserted properly or not.
Thanks
Apr 21, 2010 | Brother DCP 115C All-In-One InkJet Printer
Have replaced ink cartridges,and it still sayin
You have to go through a hardware cleaning cycle before it will recognise the new cartridge as full.
See on-line or on pc manual on how to do this.
Mar 07, 2010 | Brother DCP 115C All-In-One InkJet Printer
I have replaced all of the ink in the printer but it still comes up showing no cartridge black
make sure that the cartridge is compatible to your printer or check if the cartridge is inserted correctly.
Mar 20, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother 115C printer says no ink when plenty.
i bought new inks and inserted them , when in fact its only the yellow inks is empty yet it sends me message that found no cartridges.. waah. this printer been with me for 8 years and had it clean last year only.. what to do?
Jul 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Sir
clean and re calibrate it
Mar 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Red ink not printing!!!
To clean a print cartridge you should a glaas of water and 15-25 ml of alcohol and mix it in a small wide pan. Dip the head (usually head is mounted to the cartridge itself) in the solution and move horizontally (while the head portion only submerged) keep it there for 5-10 minutes. This should clean your print head. After the head is dry you can mout it to the printer and print. Caution: Do not touch the electronic contacts on spilt water or alcohol in it. This will damage the printer.
Oct 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Sep 17, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
1,433 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
