Question about Epson Aculaser C1100 Printer
My cx11nf is printing dots on one side of the printer HELP1
Inky
  • 691 Answers
SOURCE: epson al cx11nf print problems: Lines on side of output
This could be caused by a dirty lens on the laser unit. Try cleaning the laser window. Open the front panel (where you change the toner) and the right you will see a blue lever/handle - pull it out towards you. Now on the right side panel of the printer you will notice a little plastic panel about 2"x0.75" - open that and you will see inside another handle. Pull this handle out and back in a few times. This draws a cleaner pad across the lens. If toner has fallen onto the lens it makes the are it has fallen onto create blank lines on the print. If this does not solve your issue then the next suspect would be the PCU. Just get another one (same as C1100 if you can borrow one) and try it.
Posted on Apr 29, 2007
Sandy4u
  • 107 Answers
SOURCE: printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Posted on Jul 11, 2008
  • 110 Answers
SOURCE: dot matrix printer
Remove and reinstall the ribbon. Also, while the ribbon is out, try spinning the knob on it.
Posted on Aug 22, 2008
SOURCE: light print on right side of page
This is a for sure fix. Open front on the right side of the printer has a label that says ABC and some instructions on what to do when it skips printing throughout page and your problem. I had same problem but with all colors. Pull the gray lever and on the right side of the printer is a vertical door. Open that door and pull the lever inside. Blow that slide thing off and push it back in. Close everything back up. This worked for me.
Posted on Jun 03, 2009
tigertail
  • 163 Answers
SOURCE: We have just changed the
Oh-ho! The coloured spots are what is known as "traffic lights". To be sure these are the symptoms: You will have a black spot then a slightly larger gap then the three colours regularly spaced, the pattern will repeat every 150mm or so. If you print a black only page then only the black dot will appear, print with any colours and all four dots will be printed. It is caused by a tiny/slight scratch on the photoconductor (PCU) drum (usually caused by mishandling, a loose or foreign object inside the printer or even trying to print on stapled paper!). Polishing the drum using a very soft dry cloth can often help to get rid of the scratch, but remember to keep it away from any bright light as this will damage the sensitivity of the drum. The traffic lights will be in line with the scratch so concentrate your efforts in that area. Also, while the PCU is out, take a good look inside the printer for any loose or protruding objects, rotate the toner cartridges from above with the front cover closed (opening the front locks the cartridge carousel in position). I sincerely hope this helps as the only other remedy is to replace the PCU with a new one.
Posted on Jul 08, 2009
Text cut off right hand side
this is due to toner drop on the lens area... to clean the lens area..open the front cover and pull the lever on the right side..then open the side cover by the side of the printer... there will be a cleaner for you to pull out and forth...pull out and push back in few times to clean the lens...
then try to print see if there is improvement on your print out.
Jun 21, 2010 | Epson ACULASER CX11NF All-In-One Printer
We have just changed the photoconductor unit on our Epson Aculaser CX11NF printer. When we print or copy, we get coloured spots on the right hand side of the page
Jul 07, 2009 | Office Equipment & Supplies
Epson CX11NF
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | Epson ACULASER CX11NF All-In-One Printer
White scratches and a "breaking" mark on printout
Epson CX11NF printer problem-repair solved
To clear stripe....Open the front cover and look on the inside of the right side of the printer....There you will see a pictorial instruction showing the PRINTER HEAD cleaning procedures.
Follow them (remove tab/plug on right side, pull out on head lock arm on inside right, then fully pull out the printer head arm inside the port on the (outside of printer) right side.....Then push it back in, replace tab cover, push the lock back in (inside right-front) and problem solved.....
God Bless,
Happy Epson CX11NF User
Oct 14, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printing from Indesign CS3 to Epson CX11NF problem
hi-
Actually what i can suggest is that for you to try printing from a different application, such as microsoft word or paint. try printng a landscape image. now if its going to print it correctly call adobe since that might be an application issue. thanks for using fixya!!
May 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Dots when Printing
Replace toner then you cam make sure wether problem with toner or printer.
May 22, 2008 | HP LaserJet 1020 Printer
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printing - White Specs on page
The manuals are available on Epson's site. Here's a link to the User's Guide: http://files.support.epson.com/htmldocs/cx11nf/cx11nfug/index.htm I verified that the manual includes how to clean the printer. If that doesn't resolve the problem, please let us know so we can troubleshoot further.
Aug 21, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson al cx11nf print problems: Lines on side of output
Apr 28, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
