The wheel has fallen off and I cant put it back on. Also, I have another wheel that is broken. Please help...
    Brigadier General:
  • 3,614 Answers
for clarifications on your problem: may i know what exactly the model that you have there. kindly inout more informations on your problem, so we can analyze what were wrong.
Thanks
Posted on Jun 04, 2009
Can flipping the front wheel cause brake problems
check that a brake pad hasn't fallen out when you put the wheel back on the bike
Jun 24, 2017 | RIM Cycling
Avalon 3 wheel stroller
click on contact us and they should be able to help you find a wheel
http://www.zooper.com/index.html
Robert
Please rate this solution
Sep 08, 2008 | Baby Gear
Where is located ABS sensor?
the abs sensors( 4 of them ) are located at each wheel near the brake rotor or in the live axle housing close to the wheel
the trac control uses the same sensors and it only takes one faulty unit to put the lights on
the fault can be from a broken wire, wire fallen out of holder
Jan 25, 2016 | 2002 Toyota Sequoia
Broken wheel stud right rear wheel with drum brakes on 2006 dodge caravan. Cant get the new stud to go in. I dont have enough room for the stud to go in. Do i need to remove the wheel bearing? What will be...
To remove the broken stud use a punch and drive it out with a hammer back towards the backing plate. BY turning the axle around you will find a position or you may have to remove a brake shoe to help with the installation of the new stud. When you have it in place use larger nuts and pull it into place with the stud nut.. You may not be able to simply put the stud straight in but may have to start a bit of an angle and turn the axle to allow the stud to feed in.
Sep 01, 2013 | 2006 Dodge Grand Caravan
My tracker pro's front wheels wont turn
It is likely that the steering linkage has broken or fallen off. Examine the steering linkage and see if it is moving when the wheel is turned. You may have a broken steering column as well.
Apr 22, 2012 | Craftsman Garden
Girls 24inch glacierpoint magna bike can't raise handle bars seems like a allen type screw in middle of bar just turns and still can't lift bar does that need to be replaced or is it something else
If that allen screw just turns both directions, and it won't tighten and it won't raise up when you loosen it, then the wedge nut at the other end of that screw has already fallen off inside. Or it could mean that the screw is broken. Turn the bike upside down and see if you can remove the screw. If it is broken, the repair will be difficult, but not impossible for a bike mechanic. If the screw comes out intact, then the only thing holding the handlbar stem in place is a bit of rust. Put the bike back upright. Stand over the bike as if you were going to ride it. Grip the front wheel between your knees and twist the handlebars as if you were steering while preventing the wheel from turning with your knees. Once it breaks free, pull it all of the way out. Turn the bike over again and the wedge nut should fall out. When you reassemble, take heed of the marking on the handlebar stem so that you don't raise the stem too high. Good luck. Please vote if you found this helpful. Al K
Mar 07, 2011 | Pacific International Pacific Chromium...
My rolex gtm watch
In worst case the second wheel pinion end has broken off. In best case seconds hand just fallen off the second wheel pinion and needs to be re-fitted. Rate me, plz.
Apr 15, 2010 | Rolex Submariner 16618 Wristwatch
Broken wheel
I would suggest that you contact www.johnstonprams.co.uk who will be able to put you in the right direction.
By the way, this sounds like you have a Powertrack Twin type pram.
I hope this helps.
Mar 17, 2009 | Baby Gear
Wheel fallen off graco quattro travel system
Take it back to where you got it, if it is from toys r us, they should help you, or contact Graco, see what they can do.
Mar 13, 2009 | Graco Quattro Tour Deluxe Travel System...
Broken USB memory stick
i think it can be inserted on another special card reader to retreive the data from it
Sep 02, 2008 | Computers & Internet
k24674
jasbo
jasbo
