Question about Compaq Presario Notebook
Stuck in a start up configuration loop 3 0f 3
Stuck in a start up configuration loop 3 0f 3 0% complete
will not get to login just keeps shutting down and restarting
How to fix looping idetifying with wireless and internet connections
Identifying network ... endless loop [Solved] - Configuration ...
www.tomshardware.com > Forum > Windows 7
Tom's Hardware Guide
Jan 12, 2012 - 28 posts - ‎6 authors
My desktop is stuck on "identifying" when I try to get an internet connection. My laptop wireless works fine. I have uninstalled all network drivers ... Solution for Windows 8 Internet Slowness [Solved ...
Nov 11, 2012
Laptop stuck on "Identifying" network - Configuration ...
Dec 12, 2010
Keeps cycling between Network Cable Unplugged and ...
Mar 19, 2010
More results from www.tomshardware.com
May 01, 2014 | Microsoft Windows 7 Ultimate for PC
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
My hp pavilion dv6000 is stuck on configuration 3/3 0% and keeps shutting on n off
Turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see the SAFE MODE Option. Select the Safe Mode option and see if your machine completes the boot cycle. If it does, do a normal shut down and restart. When it restarts, you want to let it try to boot back up as it normally does. It still might try to do the configuration stuff again, so be patient and let it do it. If it gets stuck and starts shutting off and on as before, turn it off again and boot back into safe mode again.
Once in safe mode click Start/Programs/Accessories/System Tools/System Restore and select a date that is prior to the date when you first started having problems.
Don't worry,. System Restore does not delete any of your data, documents, music, pictures or videos. On the other hand, System Recovery DELETES EVERYTHING and sets your system back to how it was when you purchased it.
Mar 21, 2012 | HP Computers & Internet
My sony vaio cant configure properly
Start the Computer and keep tapping the F8 key to access the Windows Advanced Options.
Select Last Known Good Configuration.
If the issue persists, you can try start up repair from the Windows Advanced Options.
If the start up repair is not present in there, you can use the Windows Operating System disc to launch it
Mar 15, 2010 | Computers & Internet
When ever i log on the computer says configuring update 3 of 3 0% complete do not shut down. Then it shuts down on it's own and keeps doing the same thing over and over.
Turn on the computer, and as soon as it it on, keep on tapping F8 key until you see a black screen with white text. Choose the Last Known Good Configuartion option.
Jun 15, 2009 | Acer Aspire 4720 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
When I switch on Acer Aspire 5315 get message "Configuring updates 3 of 3 0% complete" for a few second then pc shuts down restarts and goes back to the same configuring updates message just...
try starting the computer in safe mode. As the computer boots keep pressing F8 until you hear a beep. The computer will or should start in safe mode, once it has everything will look big, don't worry about that for now, click on start>programs>accessories>system tools>system restore and choose a date for when you know the computer was working without any problems. Once the computer has restored it will shut down and reboot. When/if asked what mode you want to boot/start your computer choose start windows normally. I hope this helps.
Oct 22, 2008 | Computers & Internet
Configuring updates
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
bye
Jul 30, 2008 | Computers & Internet
Compaq Presario Notebook Logo
316 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
