Question about Panasonic DMR-HS2 DVD Recorder
Hard disk failure
Is it possible to purchase a hard disk and extract software from failing disk drive for copying to new drive
  • Anonymous Mar 15, 2008
    i need to record in stereo and it is in mono
  • 979 Answers
It really depends on what is failing on the old drive...accordianman
Posted on Feb 19, 2008
How do I fix a failing hard drive?
First and foremost backup your data if possible. Then if you have bad sectors on the hard drive you might try and run hdd regen. it is free and can get it from HIRAN'S BOOT CD 15.2. IT HAS SAVED MY TAIL MANY TIMES OVER.
Jun 14, 2015 | Cybertron Computers & Internet
Hard disk failure imm
Hello
The hard drive is a mechanical device that WILL fail - it is only a matter of time. Since you are being prompted that yours is about to fail, you need to get a backup of your data as soon as possible.
Use a USB memory stick, USB hard drive, CD or DVD disk or network drive to copy your data from the hard drive immediately. Once your data is copied to a safe location, you can run CHKDSK /r /f from the CMD line to check the hard drive and possibly fix issues.
If the hard drive has "Bad Sectors", you will need to replace the hard drive.
Dec 15, 2011 | HEWLETT-PACKARD Computers & Internet
May hard disk doesn't response it says error message then when I tried to run system recovery it doesn't work too. But I'll go to windows but no display then I'll try to run hard disk self test drive the...
> hard-disk self-test drive the result is 0-7 FAILED
It's time to purchase a replacement disk-drive, and then to install Windows Vista onto it, and then connect the "old" drive as a 'SLAVE' disk-drive, to see if you can copy any files onto the "new" disk-drive.
Dec 24, 2010 | Microsoft Windows Vista Ultimate Edition
When trying to restore my u series 9, (ST3160022ACE) ultra ATA 160 gig hard drive I get this message: Restore was not successful. Remove any USB or Extra Hard drives taht are connected. I have no USB or...
If by "restore" you mean that you are reinstalling Windows onto the disk-drive, to restore Windows to the "as-shipped-from-the-factory" condition, then a failure of that operation can be caused by either of three conditions:
* I/O errors reading files from the CD/DVD disks (due to dust/fingerprints on the bottom of the disks),
* I/O errors writing files to the disk-drive,
* an intermittent problem with the computer's motherboard or RAM, causing "random" failures when using the computer.
So, on another computer, take the CD/DVD disks, and try to copy the entire contents (namely up to 4.7 GB) onto the 'C:' drive, watching for any "I/O errors" during the file-copy operation.
If the file-copy completes successfully, then the copy of the files can be deleted.
If no errors occur, then it's time to suspect that the disk-drive itself is failing.
Buy a new disk-drive, and disconnect the old disk-drive, and connect the new disk-drive,
and restart the "restore" operation. If the "restore" fails on the new disk-drive,
then it's time to suspect that the motherboard has a problem.
Nov 03, 2010 | Seagate Computers & Internet
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
Oct 30, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Looking for possible hard drive how hard is it to self install --with windows xp
A few simple steps:
0. find your original Dell "System Restore" set of CD/DVD disks, or order a replacement set from Dell, or run software on your computer to burn a set of "System Restore" disks.
1. do an "inventory" of installed programs (Adobe? MS Office?) and extract any "license-keys" you need (anti-virus software, purchased software).
2. backup your E-mail and contacts and music and other files, either to an external disk-drive, or burn some CD/DVD disks, or copy across your local network to another computer.
3. turn the computer off
4. disconnect the AC power
5. remove the battery
6. remove the old disk-drive
7. determine if it was an EIDE ("parallel-ATA") drive, or a SATA drive, and buy a new drive of the same type
8. mount the new disk-drive
9. reinsert the battery
10. reconnect the AC adapter
11. take your "System Restore" disks, and "boot" from the first disk, and reinstall Windows and the Dell applications
12. run Windows Update repeatedly (Service Pack 3, post SP3 fixes, Internet Explorer 8) to get all the fixes, and the fixes-to-the-fixes
13. install anti-virus software
14. install other purchased software, using license-keys you preserved
15. download the latest versions of "free" software (iTunes, Adobe Reader, WinAmp, et cetera)
16. import your "data" files
OR.................
if both the "old" and "new" disk-drives are SATA, and you have a desktop computer with two "unused" SATA ports, you can use software, such as the commercially-sold "Partition Magic", to "clone" the old disk-drive, and to "expand" the volume to span all the "unused/unallocated" space on the new drive, e.g., copy 20GB from "old" to "new", and then "expand" the 20GB partition to the full size of the "new" disk-drive. Install the new drive into your notebook computer, and enjoy the additional "free" space.
Sep 07, 2010 | Dell Latitude D600 Notebook
Smart says hard driveabout to crash
Copy any important files now to another computer or DVD/CD or USB drive. The drive may fail soon. If you buy a new drive, some come with software which will allow you to copy one drive to another. You can buy a USB interface to have the new drive connected to the laptop and then run the software. HTH
Jan 03, 2010 | HP Computers & Internet
My computer hard drive failed and I have not yet backed up my ITUNES... how can I get my songs on my new computer
If the hard-drive has totally "failed", then reading from it will be impossible.
If your problem is that Windows does not "stat" or "run", but the disk-drive physically is OK, then it should be possible to connect the disk-drive to another computer, and copy the files onto the other computer, or to burn some CD/DVD disks.
Also, do a Google-search -- there is software that can "rip" the music off your iPod/iPhone back onto your computer.
Nov 11, 2009 | Apple iTunes
The bios test of hard disk test is failed wht can i do now
If the hard disk has failed, and you want the data off of the hard disk, you have two choices..
Purchase a extender to allow you to read the hard disk and also purchase a data recovery program to get the data off the hard disk...
Or google data recovery service and find one that can retrieve data of of bad hard drives..
Either way afterward you will need to purchase a new hard drive.. They have drives as low as 30 dollars online that can be purchased and then installed.
You will need to reinstall windows on the new hard drive you get..
Ultimately you will have to weigh the cost of repairing the computer ( purchasing a hardrive and purchasing a new copy of windows)
Versus purchasing a new computer.
Oct 31, 2009 | HP Compaq nx9030 Notebook
S.M.A.R.T Command failed
It means that the hard disk SMART monitoring system has detected problems serious enough to warn you of the growing possibility of hard disk failure. Sometimes a drive will last quite awhile after this first notification, but there is a good chance of imminent failure, in minutes, hours, days, or weeks. You should immediately look into installing a replacement drive.
You should immediately copy any important data off the drive, perform full backups, and limit use of it.
If you can install drives yourself, a new hard disk (especially Seagates) usually come with software to clone your existing drive to the new drive. Otherwise, a repair shop will be able to do it for you.
I recommend also purchasing a drive enclosure for your old drive. For whatever life it still has, it will be a good backup of your system.
Dec 06, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Panasonic DMR-HS2 DVD Recorder Logo
185 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
