Maytag Washer - Model LAT8704AAE; Agitator does not turn on during wash cyle for regular or permanent press. The agitator does work in the gentle cycle and will work during soak cycle. The agitator did turn on when I started in soak cycle then went to wash cycle, but if I go directly to wash cylce agitator will not turn on. The timer goes thorugh normal cycle without the agitator working during wash and rinse cylces for all settings seems to be working. Drain is okay.
    Brigadier General:
  • 3,917 Answers
Some possible trouble makers:
- drive belt is worn and need replacing
- you have the pump belt too tight
- both above
- motor track is rusty/sticky/dirty
- motor spring(s) is broken/rusted
- transmission oil is thick from age
- transmission agitation seal is seizing
Possible to replace the drive belt, loosen that pump belt a bit (
http://www.applianceaid.com/maywash_belt.html ) clean and lube the
motor tracks and inspect the motor track springs, sand/clean up the
motor pulley.
http://store.yahoo.com/cgi-bin/clink?a-1appliance+tSwkBf+maydrivbel.html
Drive belt.
Thank you for contacting Fixya
Posted on Jun 06, 2009
    Sergeant:
  • 175 Answers
Hi..the reason to this problem may be the belt that has
either broken or slipped off.
check it out..
thank u..
kindly rate my response..
Posted on Jun 04, 2009
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
A piece of clothing is stuck underneath the agitator! It won't turn during the wash cycle. The spin cycle still works. How do I disconnect the agitator, so I can remove the piece of clothing?
remove the agitator by first taking off the softner dispenser at the top of the agitator and then look down inside. inside you will see a half inch head bold. remove bolt and lift agitator out.
Jan 27, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Mav7200-57-58
The timer itself is bad, replace and wala! Timer Part Number: PT756240 Made by MAYTAG http://www.partstap.com/partsearch/model.aspx?model_id=47859 $70.22 + S&H
Sep 16, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
