Question about Nintendo Wii Console
Wireless sensor bar doesn't pick up Wii remote
Cat chewed through old wired sensor bar. Bought new wireless (Pelican) sensor bar, set it up and it worked perfectly right out of the box. Hasn't worked since.
Can you help? Is there something that needs to be re-synced?
  • rickaaamc Jun 04, 2009
    tried that already (both with remote and with sensor bar). Is there something in Wii console that needs to be synced?
  • 111 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-80
Posted on Jul 23, 2009
    President:
  • 4,402 Answers
Make sure the battery are in correct and then resysnc the remotes
Posted on Jun 04, 2009
My wii sensor bar that came with my wii broke. I went to buy another one from walmart, all they had were wireless. I bought the wireless sensor bar but i can't see the cursor anymore to select to play...
You should try and unplug and re-plug everything before anything else. Also ensure your Wii Remote is synced up to the console.
If there are any more issues I suggest returning your wireless sensor bar and getting a wired one. Although it shouldn't really matter if it is wireless or not. Also make sure there is nothing blocking the signal.
May 16, 2011 | Nintendo Wii Console
My wii wirless sencor bar has a blue light on but wont pick up my wii remote
Perform a remote power requirements check. For example, check for batteries in remote control compartments, replace with fresh new batteries for desired operations. Alternatively, the remote control would require power on buttons before functioning with NIntendo. Locate controls power button to initatiate process.
Jan 11, 2011 | Nintendo Mini Wireless Sensor Bar for Wii
Console not responding. have changed remote and sensor bar
This information comes directly from Nintendo's website. Hope this can be of help:
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Verify Sensitivity Setting dots:
Go to the Sensor Bar's sensitivity setting in the Wii menu.
  • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
  • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Jan 02, 2011 | Nintendo Wii Console
I have a Nyko Wireless Sensor Bar for the Nintendo Wii. I am able to turn it on, but it doesn't seem to recognize any of my remotes on the screen. What is wrong with this device?
Check the batteries in the Sensor bar, make sure it isn't being blocked by anything, back away from it and keep trying to use it at a distance... And for the sake of correctness: the Bar does not recognize anything, it merely emits infrared signals that the Wii Remote picks up and sends to the Wii via Bluetooth to interpret and calculate where to position the cursor on your TV screen. The strange thing is that the Wii Remote can sometimes be overpowered by bright lights Including the sun, so try to stay away from windows and lamps etc, etc..
You just got learned!
Aug 10, 2009 | Nyko Wireless Sensor Bar for Nintendo Wii
Remotes not picking up anything
I would suggest replacing the senor bar, it is not that uncommon that one the the Infrared LED's in the sensor bar to have burned out or go bad.
I personally use the wireless sensor bar after my original senor bar went bad
May 05, 2009 | Nintendo Wii Console
Sensor bar
have you paired up the sensor to the wii, maybe faulty batteries?
Jan 25, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Wireless sensor bar needs setting up
http://www.nintendo.com/consumer/systems/wii/en_na/settingsSensorBar.jsp
The link above will show you how to set up a sensor bar
Bless you son for saying it's wireless lol :)
I hope this helps
Nov 13, 2008 | Nintendo Wii Console
Sensor Bar
seem you can buy wireless ones now for the wii
http://cduniverse.com/search/xx/games/pid/7375745/a/Wii+Wireless+Sensor+Bar.htm
do a google for more info
riz.
Nov 19, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
481 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
