Question about Samsung YP-T10 Digital Media Player
My music is d.o.a.!
I've had a T10 for about 18months and now, without warning, it will not start up, reset, or respond. The control panel is glowing and the center button is blinking but the screen is dark. And of course, the computer doesn't recognize it when it's plugged in. Basically, it up'ed and died. Anyway to bring it back from the grave?
  • fatedtofight Jun 04, 2009
    Problem solved! My wife fixed it by inserting a bent paperclip into the tiny reset hole on the back and hit the reset button.
My wife had just pushed the little reset pinhole button thingy and it started functioning properly
Posted on Jun 22, 2009
Tip
How to reset DRM (Digital Rights Management) for Windows Media Player 12 in...
These instructions are for Windows 7.
*WARNING*
If you have downloaded songs from protected music services (i.e. Napster, Rhapsody, etc), these instructions will delete the DRM for those files and possibly make them unplayable. Please be sure to back up your DRM by copying the files in step 10 to a safe location prior to deleting them. After following this procedure, You may have to restore music that you downloaded from online services to your computer. Please consult your music services for more information.
Please perform these stepscarefully and note the warning below.
1. Open the 'Control Panel'.
2. Open 'Folder Options' and select the 'View' tab.
3. Select 'Show hidden files and folders'.
4. Uncheck 'Hide protected operating system files'.
5. In the warning message you receive, click 'Yes'.
6. Click 'OK'.
7. Close the Control Panel
8. Click the Start button. In the 'Start Search' box, paste the following:
C:ProgramDataMicrosoftWindowsDRM
9. Press 'Enter'.
10. Make a backup copy of the following 4 files to a separate location such as your desktop or a flash drive.blackbox.bin
drmstore.hds
v3ks.bla
v3ks.sec
11. Delete ONLY the following 4 files from C:ProgramDataMicrosoftWindowsDRM:
blackbox.bin
drmstore.hds
v3ks.bla
v3ks.sec
That will wipe out and reset your existing DRM.
on Mar 18, 2010 | Computers & Internet
Sharp carousel microwave
You may need your main control panel repaired
Oct 21, 2013 | Microwave Ovens
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
I had a failed tail light which I replaced but ever since then the glo plug warning light is constantly on but the glo plugs are fine and the car starts easily even on cold mornings on my 2002 C 270. How...
Dear Sir Glow plug light is on it didn't mean that glow plug faliuer, it mean the power supply is continusly on to glow plug, car will start good even incold condition,please check glow plug timer or show it technician ,but it can cause glow plug failuer in future. Thanks.
Oct 17, 2010 | 2002 Mercedes-Benz C-Class
Snow Tires without TPMS on 2006 Ford Freestar
yes you will just have a low tire pressure warning on the dashboard
Nov 18, 2009 | 2006 Ford Freestar
Control panel does not respond, filter keeps running
You have a bad relay. Replace relay and in the meantime use the breaker. You might have a spare relay in the box. Look for a relay without any wires hooked to it
Jul 18, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
If the "door lock" light is not on, the motor won't engage. These are notorious for door lock failures. However, if the door IS locking, and you have no agitate OR spin, you'll need to go a bit deeper. ---> With the front panel removed, turn the timer to Regular wash and allow it to fill. Then, with a volt stick (google it), probe the wire harness that goes to the motor. If the tip glows, you know you are getting power to the motor, but it is not responding to it. A new motor and motor controller is the fix for that. If the probe does NOT glow, the controller isn't sending power to the motor. (BTW, the motor controller is the 6" X 8" computer box in the back right corner)Why? Using your volt stick, probe the wire harness that comes FROM the timer into the controller. If it glows, you know the timer is TRYING to power up the controller but the controller isn't responding... back to changing out the motor and controller. If the probe does NOT glow, you know the timer is not sending power to the controller. In that case, it would be a defective timer. Replace it and all is well in the world. I'll warn you that a timer is much more difficult to replace than you'd think... AND I've only seen 1 failed timer since working on these. Most likely a failed door lock.
Jul 28, 2007 | Kenmore 43142 Front Load Washer
Samsung YP-T10 Digital Media Player Logo
119 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
