Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Will not turn on
LED is dead
So no way to turn it on
Expensive piece of ****
    New Friend:
  • 39 Answers
Most likely your display unit is not getting power from the power module. The display/control module has all the smarts to run the machine while the power module has the relays and switches to power the different units.
Posted on Dec 29, 2009
LG RF 21FA20PQ SET DEAD
Probably due to a defective power supply. The power supply is repairable, but usually not worth paying a repair tech to do the job. Less expensive to purchase a working unit.
Apr 23, 2014 | Computers & Internet
When I turn on the amp, the lights flicker for a second but it does nothing else. The fuse is good.
Did you check that F1 (red arrows)?. You must open the aluminum cooling in order to find the fuse F1, because it was on the inside, not visible. Usually one of the causes of rupture F1 is one or more diodes (d4/d5/d6/d7) is broken. Check and measure the diode. May also occur, F1 break up just like that, without any other components that causes. This can happen when we open a high level for a long time. It is designed so that the final transistor (which is expensive) not be damaged. Hope it helps. ecae9d89-5530-4ca0-9f14-2f9321ab0aaa.jpg
Mar 16, 2014 | Behringer Bx4500h Ultrabass 450w Bass...
THE TV WON'T TURN ON SONY TRNITRON
Sounds like the clunk most Sets have when dead cold and first turned on= a degaussing coil which will not stop the set from working.
If the power light does not make it on someone has to open the unit and see if the fuse inside is bad---not exactly a light set either and if you are not able consider either a shop or replacing the set as some repairs on this model can get rather expensive.
Dec 06, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My intermatic tranformer used for lv landscape lighting just died. Power is on but unit is dead. Do I just replace it? Is there a fuse blown?
Check the circuit breaker. Try to cycle it manually by turning either the timer wheel or the rotating the small timer pin. If you don't hear a hum and get no output, it is probably dead. You might be able to fix it, but they are not that expensive, so I wouldn't bother. In fact, I have two used ones I would like to sell because they are overkill now that I have put in a lot of LED lights.
Dec 23, 2009 | Intermatic & Malibu& 300 Watt Power/Pack...
I bought it today. it worked well. then I turned it off and on again and at the same time plugged it into USB. after that it dead! no charging icon, no led activity, and there is not any other sign of...
well in this case y did u turn it off and on again but how mucjh did this mp3 cost because some of them are expensive and will do that mines did the same and i had to return it back to ajwright
{grandpark lilsnake}
Nov 18, 2009 | Creative Labs Creative Technology Zen MP3...
LG LCD won't fully power up, randomly powers down
i have sae problem, same model . fustrating . i paid over 2,000 for mine.....
Jun 16, 2009 | LG 47LB5D Television
A1300hct
The amp is almost certainly repairable... If it's defective.
Have you tried disconnecting the speaker wires from the speaker terminals to see if the amp would power up normally?
Apr 17, 2008 | AudioBahn A1300HCT Car Audio Amplifier
Is my tv dead?
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
Sep 28, 2007 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
293 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
