Question about Transcend (589307) Media
If your pen drive was USB2, and you incorrectly disconnected it (withouth using the taskbar icon), you may have damaged it. Many of those damaged pen drives still works ok if they are connected with USB 1 interface. try disabling USB2 in your bios, restart your operative system, and if still not detected your pen drive, try making OS detect new hardware or hardware changes (to crange usb2 drivers to usb1 drivers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Reinstall driver
Posted on Mar 19, 2010
How to fransfer data from laptop to pendrive
First turn on your computer.
Once your computer and operating system are up and running, then plug the USB pen drive into an empty USB slot on your laptop.
You may have to wait a few moments while your computer detects this device and automatically installs the appropriate drivers for it, which should take no more than 30 seconds or so.
Now just click on the MY COMPUTER icon on your desktop or navigate there manually.
Look in the section titled DEVICES WITH REMOVABLE STORAGE.
You should see your USB removable flash drive listed somewhere in that section. Just double click on its icon to open it up.
Now that the USB pen drive folder is open, you can just COPY and PASTE, or DRAG and DROP any document or file from your computer into that USB pen drive folder the same way you would transfer files to any other folder on your computer.
To copy files, just RIGHT mouse click on the file you want to copy, then select COPY from the drop down menu.
Then just RIGHT mouse click anywhere in the USB pen drive folder and select the PASTE option from the drop down menu.
Once all your files are copied, just close the USB pen drive folder.
Then click on the SAFELY REMOVE HARDWARE icon in the lower right hand corner of your taskbar at the bottom of the screen. Select the USB removable pen drive option and then wait for it to say that it is now safe to remove the USB pen drive.
Then just remove your USB pen drive by pulling it straight out of the computer's USB slot.
I hope that was helpful.
Good luck and take care.
Joe.
Dec 15, 2011 | Compaq Computers & Internet
My pen 4gb pendrive is working very slow it works 800kbps
When you plug in your USB pendrive into your computer and you get a message "This device can perform faster if connected to a high speed USB2 port".
This means your computer supports USB1 which is much slower than USB2 and the latest USB3.
There may be a BIOS upgrade to configure your computer to support USB2.
May 26, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The pen drive indicates write protected and does not allow to write new files.
Three possible sources for this problem, and three separate solutions.
The following procedures assume your flash drive is assigned by MSDOS to drive E:
PROBLEM 1: Pen drive write-protect switch set
SOLUTION: move the tiny switch on the pen drive from the icon of a padlock locked
toward the icon of a padlock unlocked
PROBLEM 2: MSDOS attribute set incorrectly on any/all files on pen drive
HOW TO DISPLAY CURRENT SETTING: START > Run... > cmd
C:\> E:
E:\> attrib /S /D
HOW TO FIX WRITE-PROTECTION PROBLEM: START > Run... > cmd
C:\> E:
E:\> attrib -r /S /D
PROBLEM 3: REGISTRY set incorrectly (targeted by virus or other malware)
HOW TO DISPLAY CURRENT SETTING: START > Run...> cmd
regedit
display HKEY_LOCAL_MACHINE\System\ CurrentControlSet\Control \StorageDevicePolicies
The valid values for this are 0=Disabled (meaning READ/WRITE), and 1=Enabled (READ only)
regedit
set HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\StorageDevicePolicies
to a value of 0 (Disabled)
A fourth way to "Fix" the write-protection problem would be to reFORMAT the flash drive, but
this "solution" merely resets the ATTRIB characteristic of the top-level directory of the
flash drive (while erasing all files on the flash drive), which is done better with the ATTRIB command,
and completely fails to address the possible write-protect switch or Registry issues.
Feb 15, 2011 | Transcend (589307) Media
PEN DRIVE IS NOT RECOGNISED BY DRIVER.
Normally you don't need a special driver for usual pen drives. Are you properly removing it via the Safely Remove Hardware icon in the system tray (in right corner, near the clock on the taskbar)? If you don't use the Safely remove Hardware command, then you pen drive can be damaged. Try it in other ports or check it for proper function by connecting it to another PC.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 08, 2010 | Gigabyte GA-K8VM800M Motherboard
MSI K8MM-V - Usb on the front case work like usb1 and not usb2.
May be problem on front USB port in CPU.Connection are very loose,so ti can detect.
Change or replace cassing.
Feb 08, 2010 | MSI K8MM-V Motherboard
A problem in pen drive!
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 04, 2010 | Electronics - Others
PEN DRIVE NOT FORMETTED
This situation often comes when you're incorrectly disconnecting the drive (or even worse if you are disconnecting it when the data is copying).
The right way:
point your mouse cursor at the icon with green arrow (at the systray near the clock on the bottom right side of your screen). Press LEFT mouse button and press on the pop-out text: Safely remove USB mass storage device Drive(X:). If you see text on yellow balloon "The 'USB mass storage device' can now be safely removed from the system" you can safely remove it now.
Try to use your pen drive with another computer. Too many humidity or static charge can also damage you pen drive.
Sometimes there's nothing you can do with your pen drive with the situation you've described.
Jan 25, 2009 | Microsoft Windows XP Professional
Pen drive
Hi.
If you delete it in device manager and re-detect it, does it change? If you can see it in the taskbar, can you use the eject device icon to eject it, then remove and re-insert the drive?
Finally, try it on someone elses computer and see what result you get.
Mark
Nov 04, 2008 | Electronics - Others
Transcend (589307) Media Logo
80 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
venugopal durairajan
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
