Question about Panasonic ER 203 Beard Trimmer
Opening the Panasonic ER203
I need to replace the battery on my Panasonic ER 203.  I can find 3 screws but it still will not open up.  I need a diagram or similar to see how & where to open it.
Just insert a thin bladed knife between the two parts and gently lever apart
Posted on Jun 10, 2009
Er 398 beardtrimmer
take off the blade, loosen two philips screws, wide blade slowly remove the upper from the lower half.....replace old with new batteries
http://www.akku-wechsel.de/shop/akkus/rasierer/akku-fur-panasonic-bart-haarschneider-er-398.html
Jan 05, 2014 | Panasonic Health & Beauty
Tip
Battery replacement in Xantrex XPower Powerpack 600 > 600 watts 12 VDC >...
Battery replacement will require opening the case of the Powerpack 600. The four rubber feet must be removed first (Phillips head #2 screwdriver). Next the two orange handle halves come off starting on the radio side. The screw heads may be either 9/32" or 1/4" heads depending on age of your Powerpack 600. Use either a 9/32" or 1/4" nutdriver to remove the screws. The orange handle halves swing open like a clamshell at the carrying handle and lift off. The orange handle half on the flashlight side has two hidden latches in the handle area that must be released with a flat head screwdriver first before that half can be fully removed. Now that the orange handles are out of the way, slip off the bumpy rubber handgrip from the gray handle. On the radio side of the gray plastic case are 9 Phillips head #2 screws that are in recessed holes to remove. Once those screws are removed, the gray plastic case seperates in half and you can unplug the two pin connector going to the radio and set the radio half aside. You are now inside the Powerpack 600 and can replace the battery if needed.<br><br>Replacement 12 volt, 28ah battery numbers:<br>Sealake # FM12280<br>Zipp Battery # 12V-28AH-T3<br>CSB # GP12260<br>Powersonic PDC-12260<br>Tempest # TD28-12<br>Panasonic LC-C1228PG<br>Universal Power Group # UB12260<br>BB Battery # BP28-12
on Sep 01, 2013 | Xantrex XPower Powerpack 600 > 600 Watts...
Ni Cd Batteries for ER203 Panasonic
I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Aug 12, 2013 | Panasonic ER 203 Beard Trimmer
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
May 12, 2011 | Panasonic ER 240 Beard Trimmer
ER203 NOT CHARGING,INDICATE THE RED LIGHT.WHAT IS THE PROBLEM PLEASE.
Your Trimmer uses Ni-cd battery, which provides 40 minutes of shave time with one full charge of 8 hours. It seems that either your battery is dead or the cutting element is clouged. I'd suggest that you wash the cutting elements with warm soupy water and then try to turn it on again.
If that doesn't work, your battery is probably dead. If the unit is within warranty, you can contact Panasonic support for a replacement or else try replacing batteries with the help of a local technician or a repair center.
Hope this helps..
Mar 06, 2011 | Panasonic ER 203 Beard Trimmer
The battery on my Panasonic ER203 shaver is reaching its end of life. I found the battery number on this site. I was wondering how many batteries does this shaver take? (I have not opened it yet; I didn't...
If you open the set you can find a battery pack which is mae for the panasonic shaver. But for replacement you can put along the available ones inthe market by looking at the voltage and amperage. The curent (amp) factor is most important as this is what drives the motor for the time period.
There are also many models of the AAA or AA that can be suited to fit the space to give this VA rating.
Sep 16, 2010 | Panasonic ER 203 Beard Trimmer
Pansonic er200 need new rechargable battery
two AA rechargable batteries can be used, and yes you can replace them yourself.
Dec 05, 2008 | Panasonic ER 240 Beard Trimmer
Panasonic ER 203 Beard Trimmer Logo
854 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
