Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Wep what is the static ip for routers 169....?
    President:
  • 2,559 Answers
WEP
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
  4. Click Security under Wireless menu
  5. Under Security, Select 64 bit WEP (or 128 bit WEP).
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
  7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Configuring WPA-PSK Encryption:
  4. Click Security under Wireless menu.
  5. Under Security Mode, select WPA/WPA2-personal (PSK)
  6. Select WPA2-PSK as your Authentication
  7. Select AES as the Encryption Technique.
  8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  9. Click Apply changes to save the settings
    Posted on Jun 04, 2009
    Want to set up WEP encryption, but the router doesn't seem to accept it.
    You have to use a static IP or PPPoE IP Address in order to enable this WEP function. Use the ASCII settings to enter text. Look at the restrictions noted.
    Oct 23, 2012 | D-Link Vonage-enabled Wireless Router...
    I am stuck I did the renew and got a 169. IP address but still stuck still not acquiring an network.
    If you got 169.X ip address, it means invalid IP address. Please check your DHCP server configuration and also try to make it static IP.
    cheers
    Feb 04, 2011 | Computers & Internet
    Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
    The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
    Oct 16, 2017 | Linksys Computers & Internet
    I have no internet connection with the router but can surf without the router and only my modem
    You need to configure your router WAN settings as your internet service provider.
    If your ISP gives you static ip then configure it as static.
    If ISP gives user name and password to connect inteernet then configure router as pppoe.
    Connect your router to computer with ethernet cable then you can access it with following default link.
    http://192.168.0.1
    or
    http://192.168.1.1
    If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
    Then it ask for user name and password.
    Type user as "admin" and password as "admin" or "password" or blank.
    Then you can see configuration page of router.
    Click on wireless settings enable wireless then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.If you are able to see password in * or # then you need o add new password but if you are able to read it then note down it then you can connect with it.
    If you are not able to access router with above ip and user password then press RESET button for 10 seconds it is in back side of router.
    Then you can access it with above method.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Jun 13, 2010 | NetGear WGR614 Wireless Router
    When i connect my laptop into the modem it says local only and i cannot connect to the internet
    http://192.168.0.1
    or
    http://192.168.1.1
    Jun 13, 2010 | Arris SURFboard SB5120 Modem
    Router will not work only the power light is lit up
    1. physical connections
    2. hard reset
    3. check ip. (if 169, assign static ip)
    4. assign static ip
    5. ping router (if getting replies, access webui, reload firmware. if not getting replies, the router may already be faulty, advise to phone netgear)
    Jul 09, 2009 | NetGear WGR614 Wireless Router
    How to secure my network with the router
    If your using a wireless router set a password key for your router's WPA(Wi-fi Protected Acces) or WEP(wired equivalent privacy). The WPA/WEP key is used to connect a computer to your network. This is to ensure that only allowed computers is connected to your network.
    If your using a wired router, check your router configuration if there is an ACL(Access Control List) settings. Set first static IP addressing in your computers then enlist the IP addresses of your computers in your network, and turn off DHCP mode in your router. Now only IP addresses in the ACL settings will be allowed to your network.
    Jun 18, 2008 | Computers & Internet
    Wireless installation for DCS-5220
    Plug in the network cable first and make sure the following settings are correct:
    1. SSID is the same and set to broadcast
    2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
    3. The wireless antennae is connected
    4. The camera is located not to far from the router
    After that, remove the network cable and restart your camera.
    May 19, 2008 | D-Link DCS-5220 Network Camera
    Wireless connection on vista!!!!!!!!!!!!!!!
    Try checking if your pc is receiving a valid ip for ex. if your router start with a 192.x.x.x if your pc is really connected to your network its should also receive a ip of 192.x.x.x and if your network is unsecured and your pc is getting a 169.x.x.x ip you can try setting a static ip on your pc that's within the range of your router.
    May 07, 2008 | Computers & Internet
    Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
    258 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
