Question about Sharp AR-M237 Copier
Problem on sharp copier ar m-236 h4-01
Help to solve the problem of h4-01 of sharp arm-236 copier
    New Friend:
  • 91 Answers
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Posted on Jun 05, 2009
    New Friend:
Please where is the location of "thermostat and heater lamp of the fusing unit".
Posted on Jul 02, 2013
Ihave a code about sharp AR-236 l4-02
check the main motor so check paper draws fuser hot part, image units toner try re-seating them worse case bad main motor or control board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 15, 2015 | Sharp Office Equipment & Supplies
HAVING TROUBLE INSTALLING A NEW TONER CARTRIDGE IN SHARP ARM 257. COPIER IS NOT RECOGNIZING IT...F2 04
AR-270NT is no longer accepted by that copier. You must use AR-310NT. Or, you have a bad chip on the back of your cartridge.
May 27, 2014 | Sharp AR-168D Black and White Copier
How to change password sharp 236
Log to admin setttting and change,
Dec 22, 2013 | Sharp AR-M237 Copier
Can i use sharp ar m205 toner for my machine sharp ar205. thanks
Hi S Samra,
Its no problem you can use ARM-205 toner for AR-205. Both same powder.
Regards,
Rakshita
Jul 08, 2011 | Sharp AR-M205 Copier
Hello sir i am use the SHARP AR-5516 image copier but attach the machin to computer but driver not download plz solve problem
Drivers for Sharp AR-5516 are available at Sharp Official Support site Click here and make selection as under: -
Select
AR5516 > Windows (XP, Vista, Windows 7 etc) Depending upon the OS you have.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | Sharp AR-5316 Advanced Digital Imager...
CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
Thick black line in all copies on sharp arm 162e
Dear,
when drum clean blade is weak then strongly can not clean toner,so thick black line in all copies.
Solve: Replace clean blade or service.If your copier drum life is zero,you can change it.
Nov 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp ARM-160 I have an error code L4-11.....any ideas?? Thanks
Please verify the continuty of the LAZER UNITSand the POLLYGON MOTER is.The problem in pollygon moter
Nov 02, 2009 | Sharp AR-M160 Laser Printer
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
985 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
