Question about Frigidaire GLTF1670A Front Load Washer
Washer fills and drains at the sametime
When you start the short cycle. The machine starts to fill with water and the drain pump also turns on and starts to drain. Machine will eventually stop draining and start the wash cycle. The rinse light will be on during this process. The machine will run it's cycle then it will drain, then fill and start draining again with in 2 mins. The timer has been replaced. The hose going from the pump to the pressure switch has been checked.
2 Suggested Answers
SOURCE:
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Drain pump won 't stop running
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
Nov 26, 2012 | LG WM-2277HW Front Load Washer
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Pump turns on while filling
if it start draining while is filling the water. you need to ck the drain house. it is too long in the drain you need to pull it out little.
Feb 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire GLTF1670A Front Load Washer Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
