Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error code UO41 with refilled cartridge on canon mp830 inkjet printer with "smartchip" technology
SOURCE: Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Posted on Sep 06, 2007
agnelkj
  • 210 Answers
SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Posted on Mar 18, 2008
SOURCE: Canon Pixma MP830 ink cartridge
Canon iP4500 replaced cartridge 5 PGBK black but red light still flashes. How do I proceed,please?
Posted on May 08, 2008
SOURCE: problem with my canon printer ip1300
You can try this it works for my 1500 printer.
Go to the printer settings and turn off the ink low messages.
Switch your printer on and hold the paper feed switch down for the count of five the orange light should flash. Then switch off the power and switch back on again the green light should stay steady. If you do not come right on this one you can email me at grayjem@mweb.co.za
Posted on Aug 10, 2009
cene765
  • 787 Answers
SOURCE: canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Posted on Oct 05, 2009
Copy and Alarm Button Flashing
Regarding your Pixma MP830 printer inquiry (Canon PGI-5 / CLI-8 ink cartridges) and A200 error message, most likely the built-in PRINTHEAD is reaching it's end-of-life and may need to be replaced with a new one. Typically, the average printhead only produces ~4000 to 5000 pages before it electrically fails.
For information on PRINTHEAD failures, please refer to our support page: http://inkjet411.com/?page_id=2934
However, let's run thru the full checklist to screen out additional variables:
Canon A200 Error, Troubleshooting:
Replace ink cartridges if they are empty:
At the risk of stating the obvious (frequently not so obvious in the heat of the moment), find out if the ink cartridges are empty. When in doubt, try a new Canon original ink cartridge to see if this corrects the error.
A data cable of print head is open:
Did you just replace an ink cartridge? Perhaps you shifted a data cable to the print head.
Replace PRINTHEAD if it is damaged. Refer to Canon.com for replacement part.
Turn off the printer for some time
In other troubleshooting tips we have advised any inkjet printer not seeing regular usage to run a test print page. If you are making heavy usage of a Canon inkjet printer, consider giving it a break. This will avoid saturating the printhead with heat, prolonging useful service life.
Update the printer driver:
If you have followed all this with no success, from the printer menu (not computer) push the buttons to get a demo or test page. If everything is ok when you do this, however you get the service error code A200 when you try to produce something productive, odds are good, the print driver the computer is using has gone south (corrupt). When printing on a network, a corrupt printer driver can spread like an unwanted virus. Depending on the network, a driver that has gone rogue may be seen as an updated driver, which network will 'helpfully spread' as an update.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon PGI-5/CL-8 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=4SSnu4XhWG0
However, if your printer works routinely after inserting a brand new Canon OEM (original) PGI-5 and CLI-8 ink cartridge(s) in it, this will confirm the cause of failure.
Please visit http://www.inkjet411.com for more information or contact us directly at INKJET411HELP@GMAIL.COM
NOTE: For North American ink refill store locations and details on ink refill pricing:
Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
Fry's Electronics Ink Refill Service (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (4 stores): Downsview, Sherway, Toronto, & Vancouver
Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
(8 locations are providing ink refilling services)
-Thank you
Jan 14, 2014 | Canon MP830 All-In-One Printer
New ink cartridge and still getting error UO41
Error U041 is strictly a low ink error message, so it's strange that replacing the ink would not resolve it. Make sure the ink cartridges are inserted properly and the protective tape has been removed from the cartridge. If not, there might be an issue with the ink cartridges not being locked in place.
May 04, 2012 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Refilled Canon PIXMA MP830 and still get ink levels are low! how do you reset levels
Whoever filled this cartridge for you did not reset the chip. I own a Cartridge World ink refilling store and our chip resetter was about $100. I would not purchase from that particular refiller again because they have displayed a lack of knowledge about their product. If you buy from Cartridge World, they always reset the chips for you.
Jan 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Have replaced cartridge with one of my refilled cartridges in a canon PIXMA MP830, and am getting an alarm U071,that reads "more than one ink tank of the following color is installed". This is of course...
Printers have a mechanism to detect refilled cartridges. By default it does not accept refilled ones. But there's a work around. Have a set of two (preferably 3) cartridges , refill and cycle them. This way the printer wont be able to detect that you have inserted a refilled cartridge.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00 for MP830
try simply moving the cartridge back and forth a few times first
Because: 6A00 is a problem with the sheet feed unit. Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility. You will NOT be able to resolve the problem yourself.
Dec 09, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Trying to reset chip on refilled ink tank on CANON MP830
Looks like Fillserv.com has a chip resetter for the CLI8 color cartridges, but I don't know if that unit will reset the big black PGBK cartridge in the MP830.
Nov 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MX850 Empty Cartridge override
That code is "out of toner". I would try a genuine Canon Toner Cartridge.
Sep 24, 2008 | Canon FaxPhone L75 Plain Paper Laser
Refilling ink cartridges
I don't recommend refilling your cartridges.If if is not done properly the will leak and create a mess in the machine. I would always recommend new manufactures cartridges or a reputable re manufacturer
Nov 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
CLI8x refilled cartridges - Canon MP830 printer
Yes you can reset the chips, but you need to buy a resetter. A quality resetter is about $80. I would recommend buying refills from Cartridge World. They have good prices, a 100% satisfaction guarantee, and they take care of the mess of refilling and the expense of the resetter.
Oct 25, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
638 people viewed this question
old marine
old marine
