Question about Toshiba TN55V71 55" Rear Projection Television
Have sound but no picture
Hi, Recently the plastic frame on the back of my TV (Toshiba Cinema Series TN55V71), broke where the antenna inputs are located. Unfortunately, while hooking up the coax, the input module (for lack of knowing exactly what it is called), fell down onto the circuit board that is laying flat on the bottom of the inside of the set and I heard a slight "snap" sound and then noticed I had no picture when i went back around to the front of the TV but the sound works fine. I removed the back cover to look for a possible blown fuse. The inside label states there are 6 fuses but I can only locate 4 and all of those are good. I am guessing it is not a fuse at all but any help would be appreciated. There are no TV repair locations anywhere close to us as we are in a rural area so I would have to load it up and haul it 50 miles just to get a $50.00 estimate, Thanks in advance.
  • joe_boy29 Dec 03, 2007
    I have the same model of Toshiba. The black plastic frame/panel you speak of that surrounds the antenna inputs is cracked on mine also. I'm wondering if I can get a replacement panel. Did you manage to get one for yours? How much did it cost? Was it easy to replace/install?
    Thanks,
    Joe
    Sergeant:
    Champion:
  • 375 Answers
You either smoked the video ic or apower supply feed to it ,
Posted on Oct 24, 2007
Turn TV on and had snow on my screen... Cable will not come in,, and try reseting the TV... NO luck
Hi, It is possible that you may have selected the wrong antenna input or if you did somthing with the cable or antenna recently that would be a good place to recheck connections. Sometimes the cable company is at fault so you might try contacting them. Have you tried playing a dvd or other input on the TV to see if it works and you are getting a picture with that?
Regards,
Gil
Sep 21, 2011 | Toshiba 55UX600U TV
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
T.V. will shut itself off, power light flashes
my toshiba tv shuts itself off after about an hour or so
Jan 18, 2009 | Toshiba TN55V71 55" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
Toshiba TN61X81 HD Cinema Series Sound Problem
what type of connection did you use for your playstation 3 to your tv....
Aug 10, 2007 | Toshiba TN61X81 61" Rear Projection...
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Nov 13, 2006 | Toshiba 35A44 35" TV
Toshiba TN55V71 55" Rear Projection Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
