Question about Hoover HTC243 Top Load Washer
Hoover Elite 930 - how do i remove the inner stainless steel bowl
Something has come adrift between the inner bowl and outer tub of my elite 930. I can see a piece of stainless steel wire through the holes in the bowl which is making a heck of a noise when the bowl spins. My problem is that i can't get the bowl out. I have removed the bolts holding the key in place but there seems to be no movement between the bowl and shaft. I want to know if it is being difficult after 20+ years of not being removed or if there is something else i need to undo or remove before it will come out. Thanks
Kazong
  • 152 Answers
SOURCE: hoover elite belt change model number U4245
real simple you have to articulate the belt a little sideways and the belt should slide right between the pulley and the plastic.
Hope this helps.
Posted on Feb 06, 2008
  • 88 Answers
SOURCE: Hoover u5227-930 Elite Upright
This site shows the installation with photos:
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Posted on Jul 19, 2008
SOURCE: hoover top load washing machine, need to remove transmission
the real problem was the bearings in the motor as 1 had seized, that is where the noise was reallt coming from. pressd out bearings and replaced them , all good now , thanks.
Posted on Nov 24, 2008
landsend
  • 1066 Answers
SOURCE: Change belt on a hoover elite, model no. u4671-930
Every Hoover I've had has two screws on the bottom that you remove.  Then you lift off the cover and you pry out the brush roller. The new belt goes with one end on the motor shaft and the other end on the humped roller part on the brush roller.  Good luck it's a bit of a struggle but you can do it.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
garing
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
Seeking Manual and Help for Hoover U5075-930 vacuum
The manual will be hard to find but I own several of these Elite syle Hoovers. The plastic top cover that houses the headlight lens, attachment door, etc pops off by gently releasing the plastic tabs that hold it on. They are located on the underside of the machine. Be gentle as those plastic tabs can be easily broken.
Aug 27, 2013 | Hoover U5227-930 Elite Upright Vacuum
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
Ihoover elite supreme vaccum belt u5071-930
Remove the hood by popping the 4 tabs holding it on with a flat blade screwdriver. There are arrows on the bottom telling you where to pry. Lift the hood off you will see where the belt runs clearly. Stretch the belt into place and replace the hood. I'll include the link to the correct belt as well.
http://www.vacuummedic.com/product.php?id=8
Good Luck!
Vac Dr.
Sep 30, 2012 | Hoover U5227-930 Elite Upright Vacuum
Bottom of door makes loud squeaking on opening. I can't figure out how to lubricate. I'm wondering if removing the plastic molding on the bottom inside of the door would allow me access.
Yes by removing the inner door liner from the outer door panel you should be able to gain access to the door hinges,between the part of the hinge on the door and the hinge part on the tub is a plastic bushing that probably worn causing that sqeeking noise.
GENE
Oct 15, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Hi I also have an avanti fondue set and do not now what fuel to use in it
The burner needs fuel so go to a hardware store and get some.
Don't put the ceramic straight onto the flame, it will crack.
Use the stainless steel bowl for oil heating only.
The Ceramic bowl sits inside the stainless steel bowl.
Jul 14, 2010 | Sephra Elite Chocolate Fondue Fountain
What is the code number of the replacement sacks for the
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=U5227-930+Elite+Upright+Vacuum+Bags
Jim
Nov 28, 2009 | Hoover U5227-930 Elite Upright Vacuum
Finishing nails feel thru the holes in the tub basin in my kenmore elite. How do I get them out? I can here the tub rubing againt them.
the inner tub will have to be removed. if the nails aren't removed, they will eventally wear a hole in the outer tub
Aug 24, 2009 | Kenmore Washing Machines
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Hoover HTC243 Top Load Washer Logo
107 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
