I forgot my combination. Is there a way to unlock the samsonite without calling the support desk ? thanks
25 Other Users Have The Same Problem
Comment by Guest, posted on Jun 30, 2008
Please help me I forgot the pin key of my samsonite
Thanks
Comment by hshak, posted on Jun 04, 2008
my kid changed the combination while the suit case is opened so when i try to lock it the lock is not working
Comment by vdotmatrix, posted on May 29, 2008
f'lite Samsonite combination lost and stuck locked:
I removed the lock unfastening the 2 torx screws from the case.
Next I removed the pin that holds the RED tab thingy in place and the spring ( all this does is pushthe assembly to the right when a number is moved..... Take a picture of this before you dissassemble it. push it allthe way through..if you have fat fingers you are screwed. Anyway, remove the red thingy, and then carefully lift the remaining plate out taking note of the orientation.
First of all: the solution is aligning the cogs to 0-0-0 like from the factory. This is easy to do. when you remove the plate above , carefully do so without launching the dials and the spring into space....no matter.
Look at the bottom of the plate and notice there is a notch that will correspond to the cogs still in place on the lock assembly that should still be in place.
The cogs sit on a spring that sit on the backside of the dials with the numbers you can see when locking the suitcase.
Here is the meat:
1. with your finger or something turn the cogs until the black dot aligns outmost.
2 align the cogs so that notch will correspond to the orientation on the plate you just looked at. (that's it)!
Carefully replace the plate with finger pressure and actuate the latch-it should be unlocked and at the 0-0-0 position. If not repeat 1 and 2.
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail me..
Comment by Guest, posted on May 27, 2008
grey samsonite suitcase iso9002
Comment by Helpme111, posted on May 21, 2008
i accidentilly changed the lock combo on my samsonite suitcase (big and grey) and i dont know how to open it.
Rating: 0%, 0 votes
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Was this solution helpful? Show your Appreciation by rating it:
And smarter way is to start from a number near to your code. like if your code was 435, start from 300 . My experience says your code must be between 300 to 500.
This is a logical approach.as sometimes while setting the lock or somehow the lock keys might shift a little bit back and forth and
hence your code will change.
It took ,me just 4 minutes to get the code this way :-)
Good Luck.
Rating: 0%, 0 votes
there is a better solution than all these posted here.
Turn your suitcase (Samsonite F'LITE comfort) upside down. At this position all your numbers look upside down. Now with the help of a torch light you should see a small gap above the rotating thing (the one with which you change your number) Take the first rotating thing and rotate from 0 to 9, at some particular number you can see a small hole inside the small gap which I have mentioned before. Do the same for the next 2 rotating thing.
When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
Now you can open the number lock. :-)
Have fun
Cheers
Divya
I have no idea how the code got changed and the new code is not anywhere near the original code.
Anyhow problem sorted out.
Rating: 0%, 0 votes
Here is the meat:
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail this to me and for $15. I fix it for yaz....
Can you Help with these Tripods problems?
25 Other Users Have The Same Problem - Continued
Comment by venus2, posted on May 13, 2008
While unlocking my suitcase, I accidentally changed the number and now I don't remember the combination. Need help urgently since I have to fly our tomorrow and need to pack.
Comment by Guest, posted on May 12, 2008
forgot samsonite code number
Comment by hup1, posted on May 10, 2008
I have an expandable samsonite brief case with a double combination lock and I forgot my combination. Is there any easy solution to this problem?
Comment by golden203, posted on May 04, 2008
I have forgotten my combination? How can I open my suitcase without breaking the lock?
Comment by Nadia007, posted on Apr 13, 2008
Help. I can´t remember the three digit code for my Samsonite, and can´t open it. We are flying early tomorrow and I am getting desparate. Help me. Please.
Nadia
Comment by Guest, posted on Mar 29, 2008
How to unlock Samsonite lock problem, and notify you when a new solution is offered.
Comment by Guest, posted on Mar 26, 2008
Hi.
I have forget the cobination of my samsonie suit case. i have to fly early in the morning. Please help me. I have tried all my numbers which i may use as a combination. Please help me
Hamid
Comment by Guest, posted on Mar 07, 2008
My computer is locked in my portfolio and I can't get it unlocked. Please help on reseting the lock. It looks like it is stuck.
Comment by Seruba, posted on Mar 02, 2008
I forgot my combination no. in samsonite suitcase . Is there any way to unlock the suitcase? Kindly suggest me to unlock the suitacse. Thank you for your cooperation
Comment by aase, posted on Feb 25, 2008
HI, I am writing for my mom in Denmark who bought a new suit case and after several days, suddenly the combination lock is not working anymore, and her alarm clock is going off and she cannot get into the suit case. So if anyone has a solution for her before she needs to take her suit case back to the store (she is 82), I would be grateful to pass it on to her.
Comment by Woolley1, posted on Feb 24, 2008
My Samsonite seems to have locked itself, combination worked for 6 years but not now. It did keep jamming but always opened with a little bang on hotel floors! Not it is empty this isn;t possible. Any ideas?
Comment by Evelina3, posted on Feb 21, 2008
got the same problem. My aunt came from Europe and haven't been able to open her suitcase! Please help!
Comment by sangs, posted on Feb 19, 2008
Hi Too have same problem, I forgot the combination number.
how to get reset
Sangs
Comment by Guest, posted on Feb 17, 2008
i have the same problem. i had reset the lock to some number which i dont remember now.
Comment by suyesh, posted on Feb 11, 2008
I forgot my combination thus aint able to open the suitcase. I got a flight early tomorrow ..I am in panic..pls suggest..
Comment by Danielle99, posted on Jan 25, 2008
Lost my keys to a samsonite lock.
Comment by Guest, posted on Jan 24, 2008
i want to unlock a samsonite suitcase and i have forgotten the combinations please help
Comment by Guest, posted on Dec 12, 2007
lost my key
Comment by shaza100, posted on Dec 08, 2007
hOW CAN i UNLOCK MY SAMSONITE LOCK?
Comment by Guest, posted on Nov 17, 2007
I used my usual code 1983 to open but must have used another code to close so cannot open it. Tried different versions of code but unsuccessful
