Question about Bikemaster Carburetor Synchronizing 4-gauge Set-Motocross Gear
Cutting out at intersections hardtostartcoming
Coming up to intersections the vehicle cuts out hard to start
    Sergeant:
  • 281 Answers
My first question is, can the engine idle ok. If yes, then cutting out at intersections may well be heat soak from the engine boiling off the fuel in the float chambers. Try fitting anti-percolating blocks between the inlet and the carburetor mounts. These are red fibrous blocks machined to the same tolerances as the carby bases.
Posted on Dec 02, 2017
MOTOR CUT OUT , OR WONT IDLE AT STOP STREETS OR ROBOTS oIL LIGHTS START FLICKERING AND ENGINE STALLS
if this is happening when the foot is on the brake, then it is possible that the brake booster is leaking air and running the engine too lean.
check by idling without the foot on the brake
Feb 25, 2015 | 2005 Smart Fortwo Coupe
STARTING DISABLED DUE TO ELECTRONIC THROTTLE CONTROL
getta data stream run to obtain values and pinpoint which parts r bad-vehicles today r so complex that a code reader dozint cut it--also careful with electric throttles they can go bad and car will take off at railroads--intersections or in front of people--the old manual was safe
Mar 26, 2013 | 2005 Pontiac Grand Prix
1995 LeSabre - Starts and runs fine, but engine cuts off without warning. First time, 5mph in a crowded school commute traffic. Put in park, and started right away. Second time, after turning onto...
If the motor gets hot and cuts off and will not start for a period of time the problem would be the crank sensor. The sudden cut off and starting right back up can be due to dirty battery cable connections. Remove them from battery and clean all three of them with a wire brush and replace both bolts.
Jan 22, 2011 | 1995 Buick LeSabre
I am hoping that some of you jeep brainiacs out there can help with a suggestion of the problem with my 1992 Jeep Wrangler 4.0 hi-output. Symptoms: backfire from time to time....cuts off when driving, cuts...
i would recommend you connect a fuel pressure gauge to the engine fuel rail port and watch the fuel pressure as you drive it note fuel pressure should be between 31 and 39 psi and stay there while vehicle is being driven. if it drops check the wiring to the pump in many cases the pump connector is burned and losses connnection. also try watching the egr see if its diaphragm keeps surging try disconnecting the vacuum hose to it see it any change is noticed, common problem 4.0 engines of that year EGR's cost about 90 dollars but help stalling and emissions problems greatly.
Dec 19, 2010 | 1990 Jeep Wrangler
Fule is cutting out hard to start
uhh...if your vehicle were to come into my bay and this was the description of the problem given to me by the customer, I would completely ignore what was told me and start troubleshooting from scratch...you gave NO information about symptoms or attempts at diagnosis other than 'Hard Start' and (mispelled) "Fule is cutting out" (it's fuel, by the way). Need more information!!!!
Dec 10, 2010 | 2001 Dodge Dakota
The engine would stop when speed is reduced or stopped.
i need more details but sounds like the idol is low
Dec 08, 2009 | 1983 Ford Fairmont
Mitre for handrail, 30 deg incline into a 180 deg handrail going around a 90 deg corner
the miter should be 30 degrees. If it is mitering into a gooseneck fitting, there should have been a pamphlet explaining the three R's of stairbuilding. Rise, Rake, and Run. You will need a pitch block(triangle cut out of your step). I hang the drop over the top step, take the pitch block and set the short side of the block on the step with the diagonal toward the back of the fitting. push forward until they just meet and mark the intersection on the bottom of the rail and on the pitch block. now rotate the pitch block 90 degrees with the long side on the step. diagonal still facing back of the fitting. push forward until your mark on the pitch block intersects the top of the rail. now you have marked the top and bottom of the rail fitting. you will have to hold it as squarely to the miter fence as you can and when you cut it, cut it a little long to leave room for adjusting. the rail coming up the steps will be cut square and they will be fastened together with a rail bolt. if you dont have one, purchase the little kit. it is only a few dollars and it gives these insructions. good luck
Dec 01, 2009 | Measuring Tools & Sensors
Motor cutting out
ok you need to change your idle soliod so that the rpm stays up and gradualy comes down
Apr 12, 2009 | Daihatsu Charade Cars & Trucks
Bikemaster Carburetor Synchronizing 4-gauge Set-Motocross Gear Logo
388 people viewed this question
Top Bikemaster Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Archibald nyamukapa
Level 1 Expert
Are you a Bikemaster Motorsport Expert? Answer questions, earn points and help others
