Question about Sharp Office Equipment & Supplies
Sharp sf 2014 copier problem
I have a sharp SF 2014 copier and i keep getteing paper jams just before the fuser unit from the cassette but not from the manual feed tray i cant remember how to get in to the simulation mode to check sensors
Is my HP 2014 is bright yellow light, but it is Rashnu engine fuser error is please help
Posted on Aug 27, 2009
  • 92 Answers
Clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Posted on Jun 29, 2009
Hello sharp sf-2027 error code F3
This is a paper feed tray problem. Check there is no paper behind the cassette. There may be a tray lift problem and this can be caused by paper being trapped behind it. reset the code once fixed by switching the machine off and on.
Good luck
Oct 10, 2010 | Sharp SF 2020 Copier
We have a Sharp SF 2020 copier - can we use it as a printer?There are no ethernet or usb ports on the copier. Is there a jet-lan type of card for it?
No( There are no Sharp SF 2200 Ethernet and USB- ports, There is no a jet-lan type card. sorry. For you any help((
Sharp 2020 Code Description CC Original detection problem CH Lit Steadily: Sorter not installed, or not turned on CH Flashing: DV unit not installed, not connected properly, or not latched in place properly F1 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive. F2 Sub code 31: Image density sensor. Could be a problem with light level. Sub code 32: Drum mark sensor problem. . Does not see mark on drum or sensor not working properly. H2 Sub code 00: Fuser thermistor open. H3 Sub code 00: Fuser temperature too high. H4 Sub code 00: Fuser temperature too low. Lamp, thermal switch, connections. L1 Scan forward problem. Motor, sensor, board L3 Scan forward problem. Motor, sensor, board. L4 Drive problem; main motor, gear, sensor, bind. L5 Lens problem. Motor sensor board. L8 Sub code 01: Zero cross. P Paper feed problem or no paper PC Card counter not installed U2 Sub code 01: Memory loss. U4 Sub code 00: Communication problem between copier and duplex unit. U5 Sub code 00: Communication problem between main board and ADF.
Mar 12, 2010 | Sharp SF 2020 Copier
Error jam code
check for any remaining of torn small pieces of paper===check for no pins or other things inside in paper path=====check for free actuation of paper switches and the lever of the switches in a good condition ------later shut the machine off and then on.
Apr 06, 2009 | Sharp Office Equipment & Supplies
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
Sharp SF-2014 Copier Jams
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Aug 20, 2008 | Sharp Office Equipment & Supplies
No bottons are working
This means the developer unit is not installed . Check and instal.
May 16, 2008 | Sharp SF 2020 Copier
228 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
