Question about Epson Stylus Photo R1800 InkJet Printer
Trailing edge lines
My A4 and A3 sized bordereless prints are ruined by two distinct lines about half an inch in from the trailing edge. Doesn't happen on 6x4 prints. Any suggestions would be gratefully received.
  • Glynnie Oct 24, 2007
    Haven't tried black and white but it definitely does it in colour
  • Skykingbird Nov 10, 2007
    anybody know of a fix for the narrow unprinted edge the 1800 leaves on my 4x6 borderless prints?
  • 24 Answers
Does this happen with color or only black and white...?
Posted on Oct 24, 2007
SOURCE:
What is A3
As per ISO (International Standard Organization) A series cut sheet sizes, A4 is 297 mm long and 210 mm wide sheet. Equivalent size in inches is 11.69" long and 8.27" wide.
Nearest US size is Letter size which is 11.0" long and 8.5" wide written as 8.5x11.
Nearest Traditional British size is Quarto which is 8.0" wide and 10" long written as 8x10.
these are paper size.
Aug 18, 2012 | Sharp BR MX-6201N - 1-SD YLD BLACK TONER
Printing on custom paper sizes I can not set my a3 printer to print any longer than 42cm x 29.7cm A3, It should be able to print 29.7x 84cm half of a2
The following are the max printable areas for the Canon i9950.
A3+, A3, Ledger, B4, A4, B5, A5, 5" x 7", 4" x 6" Size
Printable Area (width x height)
A3+ (13" x 19")
322.2 x 475.0 mm / 12.7 x 18.7 in
A3
290.2 x 412.0 mm / 11.4 x 16.2 in
Ledger (11" x 17")
272.6 x 423.8 mm / 10.7 x 16.7 in
B4
250.2 x 356.0 mm / 9.9 x 14.0 in
A4
203.2 x 289.0 mm / 8.0 x 11.4 in
B5
175.2 x 249.0 mm / 6.9 x 9.8 in
A5
141.2 x 202.0 mm / 5.6 x 7.9 in
5" x 7" / 127.0 x 177.8 mm
120.2 x 169.8 mm / 4.7 x 6.7 in
4" x 6" / 101.6 x 152.4 mm
94.8 x 144.4 mm / 3.7 x 5.7 in
Borderless printing will allow you to print up to the full size of the paper but no larger than 297 x 420mm for A3 and 330 x 482 mm for A3+.
It is not possible to print on A2 paper.
Oct 13, 2009 | Canon i9950 InkJet Printer
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Jan 31, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Media curls on lead and trailing edges
Any of the following:-
Ensure the correct paper weight settings are in use. Excesive heat will cause paper curl.
Feed paper short edge first.
This is normal with high ink coverage on light paper. Use a heavier weight paper.
Your fuser may need replacing.
Jun 02, 2008 | Xerox Phaser 7750DN Laser Printer
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Feb 14, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
