Question about Nintendo DS Console
My ds stylus clip has broken and it does not stay in its place often falls out of the ds holder help
  • 44 Answers
The only way to fix it is either glue something in its place to hold it in, or buy a new stylus
Posted on Jun 04, 2009
Turntable not rotating. What should I do?
HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
Jun 20, 2014 | JVC AL A158BK Turntable
DFUD142 Dishwasher. Plastic clips holding Cutlery/Utensil Cradle sliding tray have broken. Looking for new clips or an alternative solution. Thanks
Hello, welcome to fixya
Here's what works for me, take the lower basket out and set it aside to give yourself a more work friendly environment. Now move the rack stops to the left if you haven't already and then the rack itself...example
and
Now you'll need to remove the bumpers at the back of the rack rail, example...
push down on the bumper as shown
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here individual holders # 8058638-77 from the link I pasted below at allvikingparts )
http://www.allvikingparts.com/Guide_Rail_Ball_Holder_p/pd110003.htm
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help and good luck. Let me know if you require further assistance.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Sep 13, 2011 | Viking DFUD142 Built-in Dishwasher
My stylus is stuck im my ds stylus holder
Is it too big for it? If so, you might want to try this: the stylus holder is screwed on to the inside of the backing case.
if you remove the case back you can remove the stylus holder and then the stylus and put it back together.
Be careful when taking it apart and putting it back together not to break the power switch off, it is extremely delicate. turn the speakers all the way down and make surethat the slides are in position before putting the case back on.
Oct 16, 2010 | Nintendo DS Console
Screwgun broken
Sometimes you can wrap a piece of thin plastic or paper around the stem and shove it back in and will hold it in place,- other wise there is a spring steel clip that probable wore out and would need to be replace but it wont be fun
Jun 20, 2010 | Bosch SG45 4500 Rpm Drywall Screwgun
How to remove the rack holder from a GE JMV1340WW002 microwave.
Hi best way is to remove the outer case and cut the back of the clip off, alternativly you can just lift the old clip from inside the oven cooking cavity with a flat knife or spreader untill the plastic clip on the rearside breaks off, it'l just fall down and sit in a void in the bottom of the oven and wont cause any damage. The new clip is just installed using an upward motion whilst pushing inward untill it clicks into place.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Graco lite rider navigator SL stroller broken seat holder clip
I've got a navigotor stroller and I can't unlock the back wheel brake or fold it
Dec 09, 2009 | Graco LiteRider 6712SFT Stroller
My son got a broken stylus stuck in the stylus holder help
Yes I can help you, the stylus holder is screwed on to the inside of the backing case.
Dec 28, 2008 | Nintendo DS Console
2004 RANG ROVER CUP HOLDER
maybe clip that holds cup in place has broken
Nov 17, 2008 | 2004 Land Rover Range Rover
Nintendo DS behaving erratically-Screen malfunction????
Normally replacing the touch screen will fix these types of problems. Please note that there are two screens on the bottom and not just one. You have the touch screen and under that you have an LCD screen just like the LCD on the top. You will have to remove the touch screen from the LCD as it has double sided foam tape holding them together. Also, the small clip that holds the ribbon cable to the board is easily broken, so be careful with it. If you break it you will not be able to get the ribbon cable to stay in and the touch screen will no longer work and your DS will likely not stay on.
Mar 29, 2008 | Nintendo DS Console
On then off
Hellow the problems is with you generally happen with everyone dont worry nothin harm in that may be when it fall so it fall by front side so the pin off ac is displace in that if u able to open your dc so open it and clean it and make the battery clean by the connector side okay and see the results
Jul 14, 2007 | Nintendo DS Console
Nintendo DS Console Logo
273 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
