Question about HP Compaq Presario CQ50-103NR Notebook PC
Unable to get online or wireless to obtain aol. don't have owner's manual either. attempt to go through internet explorer and can't get dialup, wireless.
Just signed up for free tral through aol and Im unable to down load softwear program.it indicates "the contents of this file cannot be unpacked".i spoke with an aol rep.and they directed me to this site...
The contents of this file cannot be unpacked. This means that the executable you are attempting to run has been corrupted.
  1. Obtain another copy of the file, verify its integrity, and try again.
  2. Another option is to request a CD from AOL, which is free.
  3. The only other option I can think of is to download the AOL setup from the Alternate AOL Download site here: http://daol.aol.com/software/95-alt/?icid=roadie_95landing
  4. You could also try downloading this file from another computer with a good internet connection.
Jul 05, 2010 | Computers & Internet
When trying to use Outlook Express 6, I get an "Error Message " stating "an error occured while establishing the dail up network connection AOL Dailer"
If you are using DialUp Internet Service from AOL, try establishing a connection first and the open Outlook Express.
If you have broadband (cable/dsl) internet service from another company, then your computer is incorrectly setup. In this case, open Control Panel, Internet Options, then click on the connections tab and delete all and any listed dialup connections or simply select the "Never dial a connection" option right under the dialup connections list box.
Also, if you are not using the AOL software, I'd recommend that you uninstall it completely to free lots of resources and speed up your computer as a result. For this, go into the Control Panel, add/remove programs and remove all AOL applications from the list.
Feb 14, 2010 | Computers & Internet
Cannot access my internet explorer browser or AOL using DSL
Looks like you may have a few different problems. Right now you cannot get your wireless laptop to see your router, correct? If this is a newer laptop for you, then the problem may be too simple. On the new hp laptops above the keyboard are light indicators for sound, volume and wireless connections. They are also buttons. The wireless one is on the right of the volume control. You turn your wireless on and off by pressing on the light. It should turn from a yellow/orange to a deep blue. Blue is on, yellow/orange is off.
Leave feedback if this was the problem. Otherwise leave more information just about the wireless setup.
Feb 02, 2010 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
No internet connection
When connecting the devices make sure that you turn on the device in this manner: modem (wait for the lights to be solid) then router, then the computer.
Check if you can get online, if not then follow the steps below:
1. Open a web browser and type this in the address bar: 192.168.1.1
2. Then you will be in the setup page of the router. You need to know what is your connection type obtained from your ISP.
If DHCP, internet connection type should be: Automatic Configuration - DHCP should be selected.
If PPPoE, select PPPoE and type the username and password provided by your ISP.
3. Then save the changes.
Once that the internet connection is working from the PC hardwired connected to the router, then check the wireless settings under the wireless tab. Take note of the SSID, wide channel, and the wireless security and preshared key.
Put those settings on the wireless adapter of the laptop and you should be able to get online.
I hope this works! Good luck!
Dec 11, 2009 | Linksys WRT160N Wireless Router
DSL-2640U connect to internet but want to setup second dialup connection from pc
Sounds like you have high speed internet and also want a dialup connection as well. Maybe as a backup.
Anyway, your pc will need have a dialup modem installed in it.
If you already have one installed then you will also need a dialup ISP account. Some times an ISP will provide dialup in addition to broadband. Ask you ISP or call AOL.
Sep 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I am changing from a Speedtouch USB broadband connection to a Belkin F5D7633-4 wireless connection on my PC. I can get the PC to talk to the router but cannot get internet - what am I doing wrong ??!!
It sounds to me that your PC is still looking for a manual connection to be made to the internet each time you want to go online.
If you're using Internet Explorer then check the following out, go to the Tools menu, Internet Options, Connections, make sure your dialups listed are selected as 'Never dial a connection'. This will allow your PC to find a connection with it looking to dial out again, so should use your router from now.
Aug 04, 2009 | Belkin Computers & Internet
Ineed help to connect online
Try here for the driver, as your model type does not show, check the label as shown on the page, you need to set up internet explorer to never dial a connection in tools>internet options>connections and then it will not attempt to dial up as it is as it should be online all the time if its a modem router, don't use the dial up as thats a different connection
Sep 22, 2008 | Westell Wirespeed VersaLink...
Belkin wireless G+ usb adapter
AOL has been and will always have problem (had to do repairs on AOL computers since 1994)
If you have a DSL or Cable connection why pay again for AOL? That means you are paying twice for the same internet connection - and AOL causes lots of problems.
For AOL problems, it is best to contact AOL.
Jul 21, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
HP Compaq Presario CQ50-103NR Notebook PC Logo
83 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
